Without “derating” it, what would be the H.P. of a non-turboed version of a GP50, or even a GP60, if EMD evr had offered one. Let’s call them GP48/GP58’s.
If I remember correctly, the GP49 is a GP50 without a turbocharger. Am I correct? It is listed as 2800 hp. If I am correct, they must put in a new engine.
They can also re-set the governor to lower RPM’s after taking the turbo off. For a given generator/alternator size/model, you can change the HP output by altering the RPM’s the engine will operate at for each thrttle setting. Also will make the engine last a lot longer between overhauls. GP-50’s and 60’s use the same block, just different power heads and RPM,s.
