We are getting some things crossed up here. First, some definations:
Dark Territory = Routes and other trackage where trains operate without block signal protection and/or authority.
Lit Territory = Routs and other trackage where signals, either automatically or centrally controlled, provide block signal protection and/or authority.
CTC = Generic term for centrally controlled routes and other trackage where block signals provide train movement authority controlled at the central location and displayed in the field by signal indication, where signals provide block signal protection and/or authority, and where some, many or all of the switches are controlled and operated from the central location (power switches), and where all switches have electric switch locks whether “power” switches or “manual” switches.
CTC is the trademark for US&S branded Centralized Traffic Control.
To enter or pass a Control Point, the train must pass at least one Absolute Signal.
ATS = Automatic Train Stop.
ATC = Automatic Train Control
Switch Conditions and States = Three States == Normal (normal route), Reverse (siding or spur), Transit (or In Transit) (when switch points are not lined for either normal or reverse positions and (usually) are in motion between those two states) and two Conditions == Locked and Unlocked.
Meet = where two trains go by each other headlight to headlight, each on its own track.
Pass = when one train overtakes another each on its own track.
Head-on = A meet where both trains are on the same track.
Rear-ender = A pass where both trains are on the same track.
Side colision or Side-swipe = any other crash other than Head-on, Rear-end, or derailment.
Derailment (on the ground) (on the ties) = wreck not caused by a crash.
ABS = Automatic Block Signal System. Used in all lit territories except the Control Point signals (a
