I decided to install a couple of sets of grade crossing signals on my layout. Flashing lights and gates that go up and down add a nice touch of animation, and they are instantly recognizable to modelers and non-modelers alike.
There are a lot of options to choose from. I’m in HO scale. I decided to install one set of crossbucks with flashers and one set of gates. Oregon Rail Supply makes a kit which built up into a nice model for the crossbucks, and I chose NJ International for my operating gates.
The crossbucks took some work to assemble. It’s necessary to wire the LEDs and run the leads through the shaft. I used magnet wire for this. There are a few small parts, and the decals need to be applied as well.
The gates are fully assembled, but they come with a stiff wire to activate the gate from below. This wire was too short for my 2-inch foam base, and it came loose as I tried
Your correct animation smacks you right between the eyes. My crossing gates are the first thing visitors Wow over. I used NJI cross arms and signals too with a Tortoise controlled by a Logic Rail Grade Crossing Pro. I went with their across the track IR detection. Because I have two crossings close together I operate both crossings with one controller and Tortoise using fishing line to raise and lower the gates. I did a post on my blog about the crossings.
I thought about that, but it would involve re-routing all the lights for three separate traffic signals through relays, and providing alternate power.
So, I’ll just argue that they hadn’t been brought up to modern standards. The layout is Transition Era, after all. Interconnection of traffic lights with grade crossing signals was specified in the Manual of Uniform Traffic Control Devices in 1948.
