Grade CROSSING
i need to find out how to build a grade crossing for a ho 22 degree radius curve.
Here’re my pictures for street crossings, with turnouts and curves…
Wolfgang
Much depends on your era and the nature of the road.
Here’s some of mine made from thin styrene “for sale” signs.( 10"x 12") The smaller signs tend to be thinner than the larger ones.
The last one is on a 26"radius curve. Sorry the pics suck.
Terry
Have you tried these? I have several on my layout and they look great.
http://www.walthers.com/exec/productinfo/184-127
They also come in 15", 18", 24", 30" and 36" radius flavors.
I make my asphalt roads from Durhams Water Putty, a hardware store product.
I build a ramp up to the track level, and put the putty on top of that, just to the top of the railheads on either side. For the part between the rails, I cut a strip of thin styrene and shim it up so it’s level with the track. I use cheap gray acrylic paint for the putty road and the styrene center. I use a bit of weathering powder between the rails, too.
Road made with foam-core board… Putty upto the rails & thin bass wood carved into boards.
OK THANKS EVERYONE FOR THE INFO AND THE PHOTOS
