I’ve run into a serious space problem in one corner of my layout and I’m wondering if a 3.5% grade helix would be too steep.
dp&s - Welcome to trains.com! [C):-)]
[#welcome] Welcome aboard.
I have a 3.51% grade on a 1 1/4 turn helix on my coal-originating mountain goat trail, but that’s only part of it. The usual grade is 4%, trains are very short, cars are very short and I assign LOTS of motive power - as many as three teakettle tank locos on a four car mixed train.
If you are willing to accept short trains of short cars, the only difference would be the number of turns in the helix - and, probably, the track radius. Did I mention that my radius is 350mm? The scale is 1:80, aka HOj, which is roughly half way between HO and OO.
Probably so.
Tight curves add to the effective grade, so your trains will act as if they are on a much steeper incline. Sadly, helixes do not abrogate the laws of physics.
Experienced modelers have found that 28" or larger radius helixes are more reliable in HO.
Gidday, I have built a 2 turn helix for HO with a 4% grade and an 18 inch radius which, with similar restraints to the ones that Chuck has already mentioned, worked OK. The helix was in a section of the layout depicting a logging short line.
BUT Cuyama is dead right, if i were to build another helix, I’d definitely go for his recommendations, however if space constrained me to an 18 inch radius again, I’d go for less of a grade and put in extra turns to gain the required height. (Needs must when the Devil pays)!
Cheers, The Bear.
If you are running steam, this is a bad idea that will cause you a lot of frustration. If you are running modern diesel, you’ll find your radius is too tight. If you are running 1st / 2nd generation diesel, just assign two locos and you will be fine.
