guage O27 track outside
Does anyone know of someone laying O 27 outside? What can be put on the track to stop the rusting?? I have heard of it years ago, but nothing recently. I am setting up my 1951 Lionel 2026 outside in the garden, using a tunnel to keep her out of the rain, however the tracks are still outside. Any help or advice would be greatly appreicated.
[?]I saw an note and a picture in the Large Scale Model Railroading, about the Late R.E. Tustin, who had his O scale line in Britain, outside, and would like to do so as well.
I would paint the track a flat grey color. Then use brite boy to clean off the tops of the track. It would look better longer. I agree there has to be an easer way then this though! Hopefully someone has an better solution. Its just an thought!
Good idea, I was also going to try to coat the joins with Vasaline, after they were joined hoping to stop some of the water. Any others?
Seems like investing in some Gargraves stainless steel track would save you a lot of headaches.
I’m working on using Atlas 21st Century because the silver/nickle won’t rust and the plastic has UV protection. The Gargrave Stainless is your only other choice
I wouldn’t try tubular O or O27 track outside. I junked a box full from an old xmas platform tha was stores in a row house basement for 40 years.
You need a clean contact surface on the 3 rails. This will be a site for INSTANT rust.
Tubular rail will rust and corrode quickly. Go for stainless steel or nickel silver.
Why not “G” ? That OTrack will rust from the inside out anyway, not to mention short out. (Remember the cardboard or fiber material that insulates the center rail)
OHHH! Slicks right about that insulation!!! Good lookin out!! Then again you can buy used lionel track really cheep too…to each is own!
:slight_smile:
:slight_smile:
