gum stump and snowshoe
I am looking for dimensions and or a diagram for the Gum Stump and Snowshoe RR plan. Does anyone have anything? Any help would be appreciated!!
http://carendt.com/scrapbook/page38a/index.html
There may be better choices in about the same 1’X6’ space, depending on your interests. The grade is very steep and the configuration of tracks is a bit limiting - for example, as drawn you’d need two locos to switch it (as the originator used). The upside is that one could build it quickly.
Byron
Here’s a variation that requires a little more room but does have a run around at both ends http://www.nmra.org/beginner/vandalia.html
Enjoy
Paul
