Ok, I found some more resurch and they have silver epoxys that are less conductive to currant than solder, still a lot of resurch to do which I was hoping to avoid.
rrebell,
Be sure that those silver epoxies don’t require heat to cure properly.
They don’t but the dry time increases with a lower temp, at least the ones I have seen so far. Remember there is no tention on these wire unlike if is on an engine. Like I said there are hundreds of products out there and even if the solution works, I am sure most of the product out there do not fill the bill but one of them proubly dose. It took quite a bit of resurch and some experimentatation to find Posi-taps and work out the details of use, time I could have better spent building my empire. Same is true in this case I guess.
