A question, has this happened before?
If so, what was the resolution?
A lot will depend on what the work order said, if it is a “99” car, it spots anywhere on the lead, and you regular guys just place it at your dock as a matter of habit…odds are that the work orders simply says spot, didn’t give an exact location, but it isn’t like you have a lots of places to put the car, so they shove it up to your dock.
If it says “99” on the order, they did their job, sort of.
99 is the code for spot anywhere in the plant.
If, on the other hand, if it says “spot at 1” or something to that effect, they should have placed it at the dock, be they were a new, part time or relief crew notwithstanding.
For the record, you are entitled to one “free” spot and pull as part of your bill, they should have used their common sense and placed the car where it would be unloaded…you didn’t mention if they pulled anything, but I assume that if they did, it would have been from the dock, so placing the loaded one back in the same place makes sense.
If it was a relief crew, and they were not familiar with the normal routine, they may have simple thought you used a tow motor to move you cars, so they shoved it on the lead and left it for you, believe it or not, a lot of places are served that way, especially if the lead tracks are privately maintained by the business.
We have a few places here with tracks so bad we only shove the cars inside the gate, because we won’t risk our motors on their horrible track.
But, from what you posted, it sound more like a relief crew unfamiliar with the regular work, who simply made an assumption about car placement, did the bare minimum, and headed home.
If the person you contacted said it was a “part time” crew, that seems to be a reasonable explanation, but you are still entitled to have the car properly placed or spotted, even if it means sending a crew and light motor out to do so.
Also for the record, do not att
