Hand made points/switches
About ten or so years ago I decided I could make my own switches or points from the excellent articles in GR. Because I’m cheap I made a bunch of them. This is an update on what went well and what I had to change. First some pictures:
Big switch:
Small switch
Here are the issues:
Interesting post, Rex. Material selection has been something I have been experimenting with. Some of my father-in-law’s buildings, made from that famous wood called “scrap,” have lasted, and others are showing the wear (delaminating, rotting, whatever). Our own efforts, often craft sticks on core material, seem to wear depending on location based upon sun exposure or drainage. Being cheap myself, finding affordable, available material has always been a challenge.
I like handlaying track. My first experience was in HO, with code 83, and dual gauge code 70 track. I’ve never actualy done any switches, however. When one ( un named) brand of G gauge track came apart due to Southern California sunshine, I was left with some brass code 332 rails in great shape, and no ties. So handlaying was required.
In my case, my G gauge handlaying has evolved over time:
originally, I wanted the scale look. At first , I used scale sized ties made of Redwood with small tacks as spikes, and polyurethane coating. What I learned from this experience is that Redwood is a very soft wood, and does not hold up over time. Then came various experiments with treated lumber.
Success came with oversized 1x1 poplar( hard wood), in 4 inch length for narrow gauge. Treated with a deck stain/ polyurethane coating. I used wood screws for spikes.
I like rugged! But that’s just me.
The most recent experiment is 1x1 garden stakes cut to 4 inch length. Very rugged, we’ll see how it holds up!
Thank You forsuggesting another wood to try!
Paul
Some good scale spikes are available. I think I got mine from Sunset. I use a modified pair of needle nose pliers to “push” them into place. I don’t think I could do that with hardwood which cracks for me after a winter under snow anyway. Treating it sounds like you’ve found the solution.
Rex
The whole reason for making my points was to save some bucks. Large turnouts cost $200+ each and I made them for about $15 each discounting the fact that I was able to use a lot of scrap rail I had on hand. Most of my cost was for the air powered operators which I would have had to add to the commercial points anyway. I don’t remember what I paid for cyprus but I’m sure it was more than cedar fence boards.
Rex
Some more on track problems - I’ve been remodeling my 810 degree helix and I may have discovered a problem you may be able to help me with - The track in my 2 1/4 turn 17 foot diameter helix is a little over 100 feet in length and raises the trains up a total of 39 inches in my new design. That makes the inner rail 2 and 1/4 ft shorter than the outer rail. All of my locos have solid axels so they must slip that 2.25 ft which I think is what is causing my gear failure problems. Is there a way of splitting the drive axel or somehow creating the equivalent of a differential?
Rex
Rex,
Wow. That is a mechanical engineering problem if ever I’ve heard of one. I am not going to hazard a guess on a D.I.Y. solution. I might suggest, however, you look across the pond to the British large-scale scene. They have some boutique manufacturers of live steam and battery powered locomotives that come in a variety of combinations with insulated and / or non-insulated wheels. The latter may be solid starting point for your “endeavours.”
Eric
Rex,
your track work in these pictures looks absolutely beautiful! Well laid.
With the old postwar Lionel, the wheels on the cars spin independently on the axels, but the locomotives do not, their wheels are fixed tightly on the axels. So, I don’t know how to do this with an engine. Some diesels had steering trucks, to position the wheels square to the rail.
There have been places on prototype railroads where they use a flange oiler on extremely tight curves. Don’t know if that would be practical due to loss of adhesion. But that’s all I can think of at the moment.
Hope you find a solution!
Paul
Rex, I’ve had a few gear failures over the years. I did some rough calculations, and it looks like your helix may be pulling around 3%, give or take. This can be significant load/ torque on gears. Suggestion would be shorter/ lighter trains, and/ or adding a helper engine. I have learned the hard way not to max out locomotive pulling capabilities.
Same issue the real trains have!
Paul
Paul,
I designed the helix to climb a half inch per two foot section or about 2.7%. The additional climb is included in the straight ramps going into and coming out of the helix. There are 30 15 degree sections 24 of which are 9’ radius and 6 are 10’ radius. At this point I could decrease the curved grade but clearances are a limiting factor. My tallest caboose is 9". Another 1.5" is tressel framing so that only leaves a couple inches for ground heaves and other tolerances. I’ll get the footings pretty close but nothing is ever perfect on dirt which keeps changing over the years.
I do try to keep the number of cars down to around three. I haven’t tried a helper engine so will give that a go this year.
Thanks,
Rex
Eric,
I’m thinking that replacing gears is cheaper than buying new locos but maybe the guys across the pond have already solved this differential problem long ago.
Rex
Rex,
Sorry, I should have been more clear. That is what I meant, that they have solved the differential problem. The also have a company, Slaters, that does nothing but wheel sets. These could be solid starts for DIY differential.
Eric
Rex,
it sounds like you’re on top of it! You’re doing a fantastic job! Also, 3 cars should not be over- pulling, which was my concern. Let us know how you make out.
Paul
Guys,
I made a mistake in the way i’ve been calculating grade. Grade is rise over run. What I did was assume that since I was going up a half inch for every two feet and that since all the foundations were level that my grade was 1/2 / 24 = 2.08%. What I actually have is 2 ft on the inner and 2 1/2 ft on the outer side of the helix. Grade actually goes from 2.08% to 1.66% depending on where the track is placed on the platform. It’s too late to make changes to the 55 tressel platforms. Loading is always going to be on the outer rail which means slip is most likely on the inner rail. Ideas??
Rex
Hi Rex,
I’m sorry, I’m not totally clear on what you are describing. I will say that in measuring grades, take the overall length, and the overall rise, instead of two foot segments, which may skew the readings. A three foot rise in one hundred foot run is 3%. This makes it easier to visualize. Hope this helps.
Paul
I was describing the error I made in calculating the grade of my helix. The inside circumference is shorter than the outside circumference hence the difference in “grade” throughout the 810 degrees. The inside length is 117’ while the ouside length is 131’. The rise is 39" for both.
Rex
Ok. I would just use the outer dimension. I’m getting 2.48%. Pretty good, Rex. That’s not too steep.
Paul
I will admit that this problem is beyond me by a few yards, but, if you always run trains in the same direction, could you not add an extra “traction tire” or two to the side that makes contact on the inner rail?
Eric
Paul,
The outside is 131 feet or 3144 inches. The total rise is 39 inches. Dividing 39 by 3144 is 0.0124045. Multiplying by 100 to get percent you have 1.24%. I can’t run on the outside because the engine front running light runs into the tressel but I can run closer than center.
Eric,
I have reversing loops on the top run at the mine and on the bottom in the town so the helix is used to go both up and down. Going up is a left turn and coming down is a right turn. Per your suggestion, I’m going to look into what the European guys are using.
Rex
Rex,
don’t know what happened, but I’m getting 1572 for 131 x12. Please recheck your calculations. A rough estimate what numbers you should be getting is the over 3 foot rise in around 100 foot run. I get 2.48% outside rail, 2.77% inside rail. All trains will traverse the entire length of the outside rail. Of course, as the run gets longer, the grade decreases. But you are around 2.5%, approximately.
Paul
