Happiness is fixing my kid’s favorite locomotive.
The only accident he’s ever had-- and it was really my own fault, I can’t blame him much. A BLI Mikado w/sound I picked-up last summer. We use it to pull the passenger train 'cause its the one he likes for some reason. (We have other sound locos, so that’s probably not the reason). Anyway, when I extended the “mainline” on around to the other side-- up to the edge of the pink foam-- about the moment I stuck in the last pin my wife called us up for dinner. I had just run the train around to the other side to test it out-- and I knew it could potentially be a problem so I reversed it in the cab (so if it accidently started, it would go away from the edge). Normally I put an edge block (a big piece of foam, well-pinned) at the end of the track but because of supper I hadn’t gotten to that part yet-- was gonna do it first thing when we came back down.
So we ate. “Good supper honey… c’mon kiddo, let’s go back and play with the trains some more!”
As I was rooting around looking for a block of foam to pin down at the end of the track, he picked-up the throttle, I heard the reverser sound, and then the throttle ease forward… uh-oh-- the realization of what was about to happen hit me about two milliseconds before it hit the locomotive…
However, I must say I was really impressed-- by a couple of things actually-- the first being the perfect arc it made as it chugged over the edge towards oblivion 40 inches down onto the cold porcelein tile below. And the fact that it was astonishingly still intact when I picked it up off the floor.
As I was picking it up I caught sight of the engineer-- I swear he was glaring at me.
The engine suffered very little damage, as far as I can tell-- a couple of extremely minor “chips” out of the tender and a cracked edge along the coal ramp, and a handrail escutcheon broken off on the loco.
I put the loco back on the track fully expecting it to be DOA
