Hi Guys , didn’t really get my answer for this and don’t want to cook anything.
Can the dcc specialties Hare trigger wire be the same wire as the dcc specialties OGAR On Guard reverser wire from the gaps needed as long as there from the Switch frog side rail? I want to run the Hare for routing where the reverse loop begins.
I’m using InsulFrogs so only one trigger gap is needed.
Reverse sections have a gap on each rail.
I want to use the inside rail of the reverser gaps ( the ones that line up to the frog ) , same as on the top of the reverser loop gaps.
Its in the green .
