Having Problems with MRC Prodigy Advance Dcc system.
I have had an MRC prodigy advance system for a while, and purchased a second remote (Advance Elite I think) and have had them both for a while. I had no problems whatsoever with how they worked. Recently though, I have been having a large amount of trouble getting a stable connection to my layout. The screen on the dcc remote is weak, and the connection is extremely spotty. I can barely get a train to move more than a foot without the power cutting out. The problem is not with the connection, as everything on my layout works fine with dc power. Is there any way I can solve this problem without having to buy another DCC system?
Are they tethered or wireless throttles? If wire less check the batteries in the cabs. Did you make 1 cab the master one? The manual will tell you how to do this. You can only have 1 master cab. I believe each cab must have a different number assigned to it. Also, you may want to joint the MRC group: https://groups.io/g/MRCDCC Joe
[#welcome]
Check the voltage to the rails, with a cheapo multimeter it should be about 15 VAC. The Power supply could be the problem if the voltage is lower than 13 volts.
Mel
My Model Railroad
Bakersfield, California
Just turned 84, aging is definitely not for wimps.
I hope that you can fix it. I will second the motion to check the power supply. I am not familiar with MRC, but an easy way to check the power supply by itself is to do the following.
1- use a sewing or other needle and insert one into the + wire. Then do the same for the - wire. Use a multimeter to then check the Volts across the needles. If it’s below 14 or so, you have a problem.
This of course does not work if the wires from the power supply are not clearly defined from one another.
If you do have to buy a new system, I would recommend a switch to NCE. It’s a controversial topic, but I am a big proponent of NCE.
A suggestion for checking rail voltage. Get 4 alligator clips and 2 4+/- inches of wire. Clip one set of the jumpers to one rail and one to meter contact. Repeat. Turn on meter. Read voltage with 14 v +/- will tell you that connection ok at that location. Try at several locations and if all readings are consistent, problem is located at a some point outside the power supply/ DCC controller.
Hope this helps
Mike
