I’m currently building a Bowser A-5 (PRR 0-4-0) for a friend, who operates with DCC. He’s given me a NCE D13SR decoder (non-sound), and the instructions, at least for my input, seem very easy to follow.
I’ve isolated the motor, and have added all-wheel pick-up to both the loco and tender. To simplify the wiring, I’ve placed the insulated tender wheels on the same side as those of the locomotive, and have installed a split piece of copper-clad circuit board in the tender, with wires from the tender trucks soldered to their appropiate sides of the board.
Because of the drawbar connection point, I didn’t use the supplied six-prong plug between the loco and tender, instead substituting a pair of three prong connectors, one on each side of the drawbar.
I haven’t yet done the final wiring connections for the head- and back-up lights
Here’s the all-wheel pick-up on the locomotive…
…and on the tender…
Here’s the split copper-clad board for current collection. The four wires coming up through the floor of the tender are from the wheel wipers on the tender trucks, while the two looped black wires to the right are from the loco’s wipers.
The straight red and black wires are, respectively, for the right and left rail power pick-ups, and lead to the decoder, as per the diagram on the decoder instructions…
Here’s the partially hooked-up decoder…
…with the orange and grey wires connected to the outboard pins of the mini-plugs - with the loco plugged-in, they lead to the
