Having trouble programming a new loco.
I have two Athearn locomotives with sound. My first one gave me fits to program so I just let it be 0003. I got another new one today and for the life of me I cannot get it to program with my MRC Prodigy.I wouldn’t mind if it would recognize 0002. What the heck can I do? I badly need your help.They both are the same brand and have sound.I am stumped and have read the book over and over.Please help me.I ordered this because it has good pulling power and is heavey enough to pull a lot of cars.I will be waiting anxiously for a good answers. Thanks.
Which Prodigy?
What locos?
What kind of fits?
It’s the MRC Prodigy Express.The two locos are Athearn with sound and they are yellow Milwaukee’s.I had a hard time with the first one so I just went with 003 and This other new one has a 2 on the side so I thought I would program it to 002. I am programming it on the program track and following the instructions by the book. What am I doing wrong???
That loco has a Soundtraxx Tsunami in it. These decoders are known to require more current than most for programming, and won’t program on many DCC systems’ program tracks. Soundtraxx makes the PTB-100 programming booster for this reason. Another option is to program it using Ops mode programming(“Program on the Main”). The problem with this is that you can not program the currently active address(if the engine is running with a short address, you can not change the short address, and if the engine is running with a long address, you cannot change the long address). For example, you can not change from the default short address “3” to the short address “2.” What you can do is program a long address(such as 2000), make sure the engine responds to the new address, and then using the address 2000 program the short address 2.
It is getting real late, I will be anxious to try that in the morning. If I have no luck I will order the board your talking about. Thanks.
Use this web site: http://www.2mm.org.uk/articles/cv29%20calculator.htm to calculate values for CV17, CV18, and CV29. Use the programming on the main option to set CV17, CV18, and finally CV29 to the calculated values.
If the cab number on the loco is less than 127, do the above but pick an arbitrary address. Like 2000. Then select loco 2000 and program CV1 to the desired address (1-127) and finally program CV29 using the above calculator but selecting 2-digit addressing.
I want to thank everyone for all of the replies. I ordered a PTB-100 so hope it’s easy installation.
CSX Robert’s comments about changing from long to short or short to long addresses in Ops Mode is not quite true – I do it all the time with an NCE ProCab Radio throttle. The trick is to change CV 29 to indicate whether you then want to run on the long or short address.
I’m not familiar with a Prodigy but I have never had to calculate CVs 17 and 18, either – I just type in the long address number I want and the controller does the calculations. But I’ve never used an MRC Prodigy Express, so maybe you have to do it that way with it.
I was not clear about this in my previous post. The part about not being able to change the active address is not a limit of Ops mode programming in general, but it is when using Ops mode programming on a Tsunami(at least according to the Tsunami maual).
I have the PTB- 100 connected to my MRC prd. adv.sq.2 and I have not had any problems setting or reading back CV’s since i put it in. I tried the PowerPax one from DCC specialties but could not read back cv’s on soundtraxx decoders. So I took it back and got the PTB-100. Now I havent found a decoder I cant read or write cv’s on.
I am at my wits end!!! Mt PTB-100 came in the mail today and now I have two locos moving at the same time.I read thru the instructions as best as I thought I could. Nobody here to help me locally.I have two Athearn locos with sound and the number on one says #1 and the other is #2. I programmed one of them and a totally different loco runs too at the same time.Please help me somehow.
It says the two blacks go to the power in.The two yellow are connected to the program track on the MRC prodigy The orange wires are spliced to the program track.The green light is blinking, is that normal?
Does the Prodigy Express even have a dedicated program track connection? If not, you can’t leave the PTB100 connected when running trains.
It has two screws for program track and two for the main track. I don’t see anywhere to put the two black wires to the power in.
For power… the Prodigy looks like it has a plug for the power, so if you want to use the some power supply you will need to cut into the wires and splice, Alternatively, you can get a separate power supply for the PTB.
As far as the green light goes:
The PTB-100 automatically connects power to the program track whenever a programming operation is started. The GREEN LED indicates the status of the programming track. A slow flash rate indicates that there is no power on the program track and locomotives may be safely placed on or removed from the programming track.
The 2 black wires should be connected to it’s own power supply. For you to connect to power in on your prodigy, you would have to splice in to the power cord after the transformer and before the plug that goes in to your prodigy power supply. DO NOT CONNECT THEM TO TRACK POWER. Read the whole paragraph #1 on the instructions to the PTB-100 pay close attention to the note and the last sentence of the paragragh. I use a transformer like for charging a phone. It converts ac to dc puts out 12 v. at 500ma. And only the yellow wires to the program track outputs on your prodigy. the orange wires to the ISOLATED program track. If you tried to program without the power Black wires supplied with power you wont get the boost needed for the tsunami’s
I am still at my wits end. I went to Radio Scack and bought a 12volt adapter 500 milliamps.I connected the two black wires to it and triple checked the orange and yellow wires. What the heck am I doing wrong. When I think the Athearn is programmed, anothe loco runs at the same time. One has the #1 on it and the other Athearn has the #2 on it. What address would you use fdor these? I need help I don’t have anyone else to turn to.
By the way, I’m getting a blinking red light.
Well, I have a blinking green light now.Every DCC locos I have are going loco on me.
I have a Digitrax Super Chief, a PR3, and Decoder Pro. I have three Tsunamis, and one Locsound and they all program just fine on the program track, just like the non sound decoders do.
