Working on my new HO layout design. I have a 20’x7.5’ loop layout (with aisle in middle) and a helix proposed for one of the corners to take trains to the below level staging area along the back wall. Due to the basic loop design I expect that 90% - 100% of the traffic will use the helix in the down grade direction, and use the No-Lix loop at the other end of the staging area to re-enter the main level. I have been reading a lot about the problems with the helix grade issues, particularly the effects of the 24" radius which adds about 1.3% effect to the planned 24" radius 2.5% grade helix. This effect will produce an equivalent grade of almost 4%.
Due to the design of my layout, I could “split” the helix into two halve sections along the 7.5 foot wide area with an approximately 3 feet of tangent between the two “half loops” if necessary. I should add that my maximum train length will be about 9 feet, which occupies about 75% of a 24" helix loop.
My questions are:
Since the primary route is downhill through the helix, am I worried about nothing?
Since the max train is 3/4 of the helix diameter, is it worth the extra fuss to design and use the half loop with tangent helix, since only 1/4 of the train would be on the tangent?
And lastly, what do you call the split helix design? The Bi-Lix?
