My layout plan has a number of track routes on different levels, primarily against the back wall. I know how it looks in my mind, but I am struggling with what happens after the run along the wall. I am doing 2" deep trackside industries against the back wall.
The layout is U-SHaped plus an extra leg, and I am thinking of keeping the high level and trying to drop the trains down to the base level using a helix in a mountain. Trains go into a tunnel at the top, come out a tunnel at the bottom. Ideally the difference between levels is 8"., but if it had to be six inches, I could improvise.
My layout is exclusively post war, although I will cheat by using tubular track in non-post war radii.
If I start at o-31, and keep increasing the diameter as I go from 3/4 of a complete circle on down, I would o-31, going into o-42, going into o-54. Hopefully that length of travel would allow enough travel for the trains to descend the required amount wihtout exceeding 4 percent.
Does this have any merit? Anyone have experience with this?
