help for a newby
Hello, I am new here and I have a question about using the site. I can get to the archive section showing all the Model Railroader magazines. In the old archive you could key in a subject word and it would give you a list of all the issues that talked about that subject. I do not see a way to do this in this archive. Can anyon help me?
thanks,
Bob
Yes, someone surely can, as this question has come up recently. I believe someone mentioned a way to do this, and hopefully they’ll chime in shortly. I just wanted to say welcome to the forums. I’ve gotten lots of invaluable help here.
-Matt
Welcome to the forums, Bob. Your first posts are moderated and may not appear right away, but after you post several times, things will be better.
I also don’t know the answer, but check back – I’m sure someone knows.
Go to this site, do your search, them come back to look at that correct issue:
https://rrmagazineindex.org/about.php
It’s not perfect, but if works a lot of the time.
Sheldon
Matt, John, and Sheldon, thanks for all your help, much appreciated.
Sheldon, I tried that link and got 2288 hits in 115 issues of 32 magazines. It was a little boring to go through all those hits but since I knew the magazine was Model Railroader I could skip through it quickly. The point is that I finally did get the hit I needed and then went to the archives of MR right here and got the article I wanted. THANKS.
Bob
Glad it worked for you. If you click on the advanced search option, you can search just one publication…
Sheldon
