You know the ones with the pizza cutter flanges-I’m contemplating code 70, so… anyone aware of drop in wheel replacements? NWSL? I’ve never seen any offered, and I’d rather not have to lay a line of code 100 to be able to use them, and don’t really want to seem them sit on the shelf, either. Thanks- Mike
Telephone NWSL to see if they have any solutions.
For the U25C; I’d re-chassis it with a Spectrum E33 - same style of truck.
I managed to rewheel my U25C with NWSL 40" wheels for Athearn diesels. I pressed the axles out of the NWSL wheels and put them on the Rivarossi axles with some masking tape and super glue. It’s extremely crude and I may redo it eventually, but it works for now.
I don’t know of any direct rewheel kits for the U25C and GG-1. One common method used on old Rivarossis was to grind the flanges down to RP-25 size. At least a few here have done it, so you may be able to get some tips on doing it.
There is another option…Kaslo Shops apparently makes a powered chassis to fit the Rivarossi U25C shell.
http://www.central-hobbies.com/products/kasloshops.html
Part # HCK-2. It’s about a third of the way down the page. Kind of expensive, but it might be worth it.
NWSL does make direct wheel replacements for the U25C that press right on to the original axles.
HO AHM/Rivarossi U25C upgrade nickel-silver wheels
#2693-6 $7.95 HO AHM/Riv U25C 40"/110 wheels (12) to fit original geared axles
#2694-6 $7.95 HO AHM/Riv U25C 40"/88 wheels (12) to fit original geared axles
http://www.nwsl.com/wp-content/uploads/2009/Price_lists/Product_Price_Lists.pdf
There’s also a Yahoo group for the Kaslo Shops U25C project: http://groups.yahoo.com/group/u25cproject/
I repowered mine with a can motor, flywheel, and a belt drive. http://tinyurl.com/y7qvub5
I don’t know of any wheel replacements for the GG1, unless you could obtain wheelsets for the IHC-Mehano version (which IIRC aren’t RP25 but are smaller than pizza cutters) and press them on the Rivarossi axles. The Rivarossis have well-detailed but fragile plastic wheel centers, so the only safe way to reduce the flange depth is to chuck each wheel tread in a lathe and turn them down one at a time to avoid putting stress on the plastic castings.
