I’ve been “playing trains” for about five years now, but I rarely do anything that cool–just the original loop that came with my set and maybe an add-on here and there. Well, this year I got snazzy and bought tons of track and built an enormous layout for my train in my den. It is a mammoth oblong/square circle that fills the whole room and has an interior loop, and another small loop off one side that is almost a full oval but ends with the “Track Gang” accessory working on the track. It is so big that I used the graduated and elevated trestle set and it only took up about half of the track even though each trestle is spaced 10 inches apart. I’ve got the truss bridge and girder bridges, and I’ve got both manual and remote switches and a crossover. I mean it’s really cool. I think I got too big for my britches!!!
In fact, it’s so cool that my train won’t run even when I disconnect all of the accessories. I mean it will run the locomotive and the tender and one other car, but it stalls out if you add 2 or 3 cars to it and then the transformer starts flashing. My Berkshire locomotive was literally smoking (not from the puffing “steam”, either!) going up hill. If I just put the train on the track with all the cars (I have 8 lighted cars and 2 non-lighted cars,plus the loco and tender), it doesn’t even have enough power to just light them all up sitting there.
I’m using fastrack and the standard CW-80 that came with my Polar Express set. I thought I might need to add another transformer, but someone I know said enough power is not my problem…they said my problem has to do with resistance and that I just needed to connect another piece of track with wires on it to my transformer. To me, that is just hooking up the same amount of power to the same track, but they said if I just hook more wires on the same track to my transformer it will work because there will be less resista
