I recieved a MRC Prodigy system and I want to put it on the layout with a switch to keep the DC part intact so I can continue running my older equipment, but I’m not sure how to go about doing this…a DPDT switch is needed here, right? How would I wire it?
Another question…is this system compatable with LocoNET? I would like to get some extension panels for around the layout.
I use NCE at home, and Digitrax at our club. I am currently installing signaling and detection on our club layout.
As I am seeing it, you can use most of the Digitrax modules with any DCC system. Particularly the detection, signal, and turnout boards. However, you CAN NOT connect them to any other DCC control bus except Digitrax LocoNet. What you CAN do is run a second control bus. This would be a LocoNet bus for your Digitrax boards. To control this bus, you would need to connect it to a computer via one of the Digitrax interface connections available. Control programs would have to be one of the programs that Digitrax recommends. Also, you should use all external power supplies and wallwarts for board power.
If you didn’t want to go that route, CTI also makes a computer driven control system. With this system, you also have a separate control bus and have to use their hardware modules.
If your MRC Prodigy system has a computer interface on it, you may be able to also control your trains with the same computer and program. You will need to connect them together with a second interface / cable. Sorry, but I can’t answer any questions about the MRC Prodigy system and what it can and can not do as I don’t have one and have not even seen one.
larak…thanks. That’s just what I wanted to hear. I’m going to move the turnout control over to a dedicated power supply and connect the two… gandydancer19…I’m sorry…I meant XpressNET not LocoNET. great info to know however. I’ll try again to present this question. [#oops]
The question to the group…Is a MRC Prodigy system compatible with XpressNET? I can’t seem to find that info anywhere.
We have had a few people on these forums, as well as some of my strong-headed customers, do the same thing. It doesnt take much to fry your DCC system with DC present on your layout at the same time.
When running between DCC track sections and adjacent conventional DC powered tracks, both rails must have insulating gaps. The DC supply used must have some form of current control.
A 5 to 10 Watt 12 Volt lamp placed in series with one of the DC power pack track leads will work for this purpose. This allows the DCC booster to drive the locomotive onto the DC track with minimum interruption and stress to the booster, decoders and locomotive wheels.
When the lamp lights as the locomotive bridges the gaps it acts as a “shock absorber” between the DCC and DC track sections. It is best to cross these gaps quickly and not bridge the DCC and DC sections for any longer than necessary.
So even with center-off you still run the risk of bridging the gap if someone forgets to center-off the toggle. And when the toggle is center-off’ed you have a dead track till you move the engine by hand. If you consist is also an issue.
