Dale…
Welcome and hope you had a Merry Chrstmas!
My advice to you, is to sit down, with a pencil and some paper, and write down, what you want to accomplish with the model railroad you want to build.
If you are new, I would try to keep things simple - you can always change add or improve to wahat you already have down the road.
You don’t need to do or have everything at once…take your time and set basic goals, accomplishing them one at a time.
After you write down your notes, I’d make some sketches of roughly the size and shape of the room you have to build in and then start to visualize how and where you want your track to position.
Simple graph paper, available at most office or school supply stores, is a great starting point.
This will allow you to ‘scale’ down your drawing using the squares as deminsional increments - i.e, each small square = 4 sq inches, etc.
I’d draw a outline where my benchwork will be and then you’ll be able to sketch a track plan.
This is just a point of departure and something to get you started.
Have you purchased any track or power supplies yet?
If not, and you’re planning to go with DCC, you may want to start out with DCC from the get-go.
The initial investment is a little pricey, but this is one area you do not want to skimp on, so just bite the bullit- you don’t need the top-of -the-line, system either, but you want to be able to have access to the NMRA Compliant 28 function control - Both Digitrax and NCE make very good products and Digitrax probably has the largest available add-on accessories.
Both systems are easy to use, my personal prference being Digitrax, mainly because it’s so expandable.
The second biggest investment and probably your first consideration after a track plan, is the track itself.
There are basically two types: Ready to Run sectional track that allows you all kinds of possible configurations(there are many track plan book
