Double-deck layout; lower deck 42" high and 24" deep; upper deck 59" high and 16" deep.
Three LED strips (SMT3528) under the outer edge of the upper deck. Tracks and trains all over the lower deck. Lights on.
WTH moment.
The trains closer to the outer edge on the lower deck are casting a shadow towards the aisle because the upper deck does not reach far over to illuminate it.
How do you, with double-deck layouts, solve this problem and achieve nice, uniform, diffuse illumination throughout?
Givens:
primary operator heght 6’3",
ceiling height is ~6’7",
drywall over joists,
some pot lights,
won’t use CFLs or flourescent tubes of any kind due to height restrictions and/or environmental concerns.
Thanks in advance!
EDIT: included my own height, adjusted ceiling height
My layout is only partially double-decked, with the lower level 36"-38" high, and the upper level at 59". The height of the suspended ceiling is about 81".
Layout depth varies…in the first photo below, the two levels on either side of the aisle are about 32" deep, while those at the end of the aisle are 39" deep…
For the aisle shown below in an under-construction view, the depth of the lower level is 21", while the upper is 26" deep…
…and seen here with the lights and fascia installed…
The upper level and all of the single-level portion of the layout is lit by double-tube fluorescent fixtures above the suspended ceiling, mostly 4’-ers, with a couple of 8’-ers, while lower level lighting is done with lightweight electronic fluorescents (twin tube 4’-ers). The latter were placed as closely as possible to the rear of the upper level fascia (not yet in place in the photo below)…
The stacked staging yards are located across the aisle from the previous view, and are lit in a similar manner…
I intend to put a couple of “fill” lights nearer the corners of the deep portion of the lower level, at the end of the aisle in the first photo, using 60watt-equivalent Daylight LED bulbs.
I’m reasonably satisfied with the lighting as it is, but may change the 4’ ceiling fixture
I wish I had your 81" suspended ceiling in my basement.
How do you manage the 32-39" benchwork depth on the main level at 36" height?
Is it meant for sitting and not standing, because I cannot imagine being able to see the back of that level, at least at my height (6’3"). I’m having hard time seeing the back at my 24" lower level at 42", because of the 16" upper level depth, which is at 59" as well.
I see that your upper level in the other photo (26" deep) overhangs the lower (21" deep). How does it feel operating at those deck ratios?
It definitely provides for good illumination from above, although personally I would be bothered not being able to see all the nice scenery around my track.
Also, in that photo, are the 4’ tubes at the back of the fascia the only illumination above the lower level?
I’m about your same height 6-3, 6-4, and I’m looking at building my dble decker at 40" & 60".
I definitely want to lite it with the newer LED strip/tape lighting for a number of positive reasons. Lighting the lower deck seems to be no problem, BUT I am wondering how to use that same lighting for the upper deck?
Have not finished putting Masonite board over all of the insulation yet, nor over the ceiling, but hopefully you get some idea of what I am speaking about?..how to mount LED lighting to the ‘Masonite ceiling’ to lite up the upper dcek of a dbl-deck layout??
A combination of ceiling and below-the-fascia lighting might be needed in both of our cases, to avoid the shadows created by just the fascia mounted lights.
It will also need to be balanced so that one does not overpower the other.
Have you decided whether you are putting a valance on your upper level or not?
If you go without it, then the celing lighting would illuminate both the upper level and exposed lower levels. Perhaps twin 4’ LED tubes placed around the layout/aisles shape would work better than LED strips, due to the distance.
Before you close up the ceiling, mark where those roof rafters/joists are so you can secure things to them (suspended lights or what not). I wouldn’t bet a head injury on thin masonite board holding much on its own.
Wonder it there is some sort of a way to create a ‘tube type’ LED utilizing those flat LED strips glued to the ceiling, and then some sort of thin clear plastic sheet material bent over the strips in a half circular manner?
…just brain-storming
I would be looking for a very minimalistic light source for that upper deck that would hopefully not have to utilize those fluorescent type tubes and their end fitting receptacles.
The top deck is the easy part - you just hang a valence the same width as the top deck, the the lights you install will be shining straight down on the upper level scenes. No real shadow issues. It’s the wide difference between upper and lower deck widths that start causing issues, for the lower deck. Wayne’s all looks great except the one spot where, indeed, the lower deck sticks out a bit more that anywhere else.
My plan is to keep my widthes pretty close to the same - and none more than 18" typically. The only wider part will be for my yard, and there I will have the saem lighting issues, because I will not be extending the upper deck over the full width of the yard, in fact the upper deck at that spot may be very narrow, I don;t want to have someone blocking the yard operator while trying to switch some industry on the upper level at the same spot. Rather than strips, that area may have ceiling mounted lighting to light both levels. If not right against the walls, even a 12" wide upper deck at that point won’t cast a shadow on the lower level.
There are also available commercially, LED squares, either 1’ or 2’ squares, which have 2 wires coming off them, they run off a 12V DC power supply just like the strips. By the time I actually get to where I need to install that, I’m hoping they will have RGB ones so I can extend my blue night lighting over the yard area, as well as the dawn and dusk features - everywhere else I plan to use strips, based on some testing it’s likely to be 4 strips total, 2 white, 1 RGB, and one blue.
The lower level is meant to be operated from rolling office chairs. The upper level can mostly be operated while standing, but I do keep a couple of step-stools handy for occasions when manual uncoupling is necessary. Turnouts are also manually-operated, and some require the step-stools, but they will eventually be operable (manually) from the fascia.
Because the two levels are not operated at the same time (the layout is DC, and meant for one operator), the one not in use pretty much disappears, as my focus is on the one I’m using.
Yeah, the fixtures, all double-tube, are the only lighting on the lower level although, as I mentioned, the deep portion across the end of the aisle in the first photo will be getting an LED bulb in each corner, probably about midway between the fascia and the backdrop.
These two photos were taken before the second level was added…
…and this one, of the area between the two photos above, after the second level was
those are beautiful shots and scenes, and excellent detail work. I can only hope my layout some day would look similar.
You said to instead put the lights in front of the backdrop. I know that would create long shadows towards the operator, but has anyone considered/did put the lights at the horizon level, next to the backdrop. Most of the sky on a nice clear sunny day pales to the horizon from a deep blue at the zenith…
There are plastic LED diffuser strips that I’m thinking could make the LED strips look more like flourescent tubes, but the length needed to cover many feet of LED strips might not be worth it. In China diffusers cost $0.25-$1/ft and in North America they are $10-$20/ft. MEH.
I think that it would be difficult to hide such lights from some viewing angles, and the effect is easier to accomplish using paint on the backdrop…
I bought a not-too-dark blue for the upper sky, dividing the paint into three lots. The original colour was used near the top, and the mid-sky was done with the same paint with some white paint added, while that at the horizon was from the third lot, with even more white added. I tried to blend the colours where they met while the paint was still wet, but with only limited success, as the paint dried too quickly. Where the second level was to be added later, the process was duplicated for both levels, which looked a bit unusual…
The fluorescent lights do cause the colours to fade over time, and had LEDs been available or now, if they were affordable, they’d likely be my choice. If the tube-style LEDs come down enough in price, I may start replacing the fluorescents, although I have a fairly large supply of replacement tubes. I found a good-size lot of 40watt tubes at a good price, and removed all of the 32 and 34watt ones I had been using as the original 40watt ones expired. For a number of years, at least around here, the 40s seemed to be unavailable.
The small diameter 34s in the electronic fixtures lighting the lower level seem to have a lumen rating very similar to the old-style 40s in the ceiling. On an earlier, smaller layout, I used colour-balanced tubes, but there were only four doub
That’s why you put in the valence, and not just put lights on the ceiling, the idea being that the valence board would hide the lights from direct vision.
Michael’s is a high-end setup, imho, because he is very particular about the colour rendering so the light boards and the LEDs end up costing more.
I do not see myself soldering hundreds of SMT LEDs despite having over 30+ years experience in electronics. If I really had to, I’d use a reflow oven to speed things up, but because I’m being cheap, I’ll look for SMT 5630 LED strips instead.
I’m sure that if one is not too specific about >80% CRI, one could find cheaper 5630 LED strips from the usual places such as ebay, amazon, etc.
While my 3528 are also bright, I had problems with shadows on the lower deck when these are mounted behind the fascia under the upper deck. This is due to the upper deck being 16" deep while lower deck is 24".
This could potentially be resolved by either extending the upper deck to 24" in which case it would block the view of the rear lower deck; or mounting brighter LED strips on the valance, and making it 24" deep so it illuminates both the upper and lower deck below it.
I don’t know if there’s a win-win situation as there appear to be too many parameters involved with multi-deck layouts (and low ceilings in my case), so I’ll try to go for the next best option…
I admit I need to learn a lot more about the LED subject before I start buying them.
Is his ‘system’ of putting together a ‘fixture’ a somewhat dated technology now (3 years old?) ? It seems as though this LED tech is ever changing really quickly, and more custom options are now becoming std fixtures rather quickly.
Would the idea of running several (or multiple) rows of LED’s down the underside of the upper deck help with lighting the lower deck, ie: one row just behind the fascia, and one row down the middle of the overhead deck and pointed outwardly?
Michael’s system is current for the home environment. It has a high cost of ownership because of the investment into good quality LEDs, custom made printed circuit boards and the time taken to solder each LED to it.
Consumer LED strips on thin flexible circuit boards strips are fabricated in huge volumes on automated factory lines, and generally use cheaper LEDs to keep the costs down.
And yes, what I’ve seen in general, modellers use multiple rows of LED strips, behind the fascia and along the middle of the overhead deck. These are mixed strips of warm white, cool white and blue, i.e. warm white/cool white overhead, and warm white/blue on the fascia.
Note that the blue is dimmed down to the minimum brightness to only add the cold accent. Blue is also used for night-time running which, with or without dimmed down white LEDs for moonlight, looks amazing.
Check this one out for example (1:46:45 in the video):
In general - Pay attention to color temperature. I’ve seen some LEDS and other lights that have a very unnatural look to my eye. You may already be locked in to a color temp if you have lots of finished models. If you have been painting and weathering models in say incandescent light (3500K) and then start lighting your layout at Daylight temps (5000K+) your models may not look right due to the color shift in the new light.
As for the upper valence - The lights at the edge of the valence will be little solar flares without some diffusers or other view blocks. This is especially true when looking down the scene parallel to the valence. You will need to figure out sight lines and diffusing to avoid bright spots for the viewer standing in the aisle.
I use warm white CPFLS for my layout lighting – I have around 40 or more fixtures distributed between the two decks with 40 watt equivalent bulbs in them. I arrived at that choice after lots of mock ups and experimentation with all of the viable options available at the time. I am very happy with the look - both decks are very bright. If I were to start over - no question it would be LEDS. I may still convert at some point.
That’s a great point about colour temperature with regards to weathering, did not even consider that, thanks!
I’m hoping to mix the warm white, cool white and blue together to be able to get any time of day/night, if ever needed.
Is it viable not to worry about lighting at the moment, as I’m about to start building the benchwork, and just make provisions for it during the construction?
Or, is the lighting done while the benchwork is being constructed (along with the backdrops)?
5000K CRI 82 CFLs mounted in party light strings on 24" centers above cracked ice drop ceiling acrylic diffusers. 6500K LED strips (5050-300) along front edge recessed 1-1/2" above fascia lip to prevent glare. CFLs provide the bulk of the light while the LEDs add additional blue without casting blue onto the backdrop. The combination of mostly 5000K with a little 6500K thrown in results in a convincing outdoors light effect even with the relatively poor CRI of the lamps. At only $1.50 per lamp I can’t complain about CRI.
Roof flashing aluminum roll used as reflectors. Home Depot
Lower deck same arrangement except CFLs mounted inside upper deck grid benchwork. Precut aluminum step flashing used as reflectors. Home Depot
Upper deck valance extends 1" below LEDs so they cannot be seen.
Lower deck not yet constructed. Lower deck lighting is turned off in above photo, obviously. Upper lighting fascia bottom edge at 75", upper deck at 53", lower deck (will be) 32". My height 5’10". Maximum upper deck depth 24" (except in scenery only room corners).
