Fellow Modelers,
I have been debating over and over on how to deal with engines w/long hose. Clipping them would affect the appearance however they are annoying especially on non-flat tracks
Any advice would help greatly.
Thank you in advance
Fellow Modelers,
Ummm, WHICH hose?
If you’re refering to the Kadee coupler trip pin… I’ve removed all of mine.
I don’t have any under track uncouplers and I experimented with a couple of RIX uncoupling wands but didn’t find them all that helpful.
If you use a Kadee coupler height gauge there is a shelf that is supposed to gauge the height of the trip pin. You have to cure any sagging couplers/draft gear before making the trip pin adjustment.
In HO the pin clearance should br 1/32" or .031"
http://www.kadee.com/html/205_206ins.pdf
In N scale the clearance is only .010"
Good Luck, Ed
If the trip pin is low it can be bent up to proper clearance. Kadee makes a tool for this
http://www.kadee.com/htmbord/page237.htm
However, I use a small channel lock pliers to adjust mine.
Put a small upward bend at the end while keeping the main part within specifications.
Me too. I just kind of curve the hose up a tiny bit.
On some equipment like snowplows I use a different style dummy coupler without the airhose. I don’t ever plan on using the coupler in operation so it doesn’t need the hose.
I use the air hoses to uncouple. I made some uncoupling tools which I saw several years ago in MR. They worked so good I removed all of my magnets.
j…
Clip them off and experiment with PWRS MagnaLock Brake hoses. Saw a discussion in the MRH forums.
Since the OP mentions engines only, it would seem he might be talking about MU hoses.
Ed
Post picture of the engine with long hose. I don’t know of any with this issue.
