Help please! New to DCC. Programming used engines to my Power Cab
Hey guys. So I purchased a used lot off someone. He never had it set up except to test it all out and assured me everything works perfectly. With it came 2 atlas engines with decoders already installed and an NCE Power Cab. I have everything hooked up but am trying to program these engines to the Power Cab. Does each decoder have a specific code or ID number? If so how do I find out what they are? If not how the heck do I get this to recognize these engines? Thanks!
Did your Power Cab come with a manual? If not, you can download one from the NCE website. Also, did you try operating either of the locomotives on address “3”?
If neither works on “3” or the cab address, you can always reset the decoders to factory settings then program it to whatever address you want.
I do have a manual and yes I tried both on 3. I have a little section of test track to test these (individually) and selected the program track option. On both engines I get “cannot read cv”. I should add both of these decoders are NCE also so from the research I’ve done it should be able to read the CVs. Unless I am doing something wrong.
Both of them I just tried again using number 3 and i get the lights to come on when i hit the headlight button but I get no movement.
The brand of decoder doesn’t really matter. Your Power Cab should be able to any manufacturer’s decoder.
Did you try the locomotive number on the side of the cab? That’s what a majority of modelers use for their decoder address. If address 3 doesn’t work then I would try that one next.
Lastly, do the lights turn on and off when you press the Headlight or “0” button on address 3?
I tried the road numbers and nothing but tried #3 again and I got both engines to get the lights to turn on with the headlight button however nothing else will work. No movement at all when i move the wheel up or down.
When that happens to me, (cannot read CV) usually I don’t get the lights or anything else to work.
Edit, you posted while I was writing this post. I’ll leave it as is, but if the headlights work with an address of 3, then 3 is the address.
Before we go there, there are some oddities about the NCE system. The PO may have programmed a short address as a long address. By that I mean 100 is a short address, but he may have used 0100 which is long.
Assuming that is not the case, there is a decoder recovery option discussed starting on page 48 of the Power cab 1.65 manual. I would try that, then cycle the power on and off to your Power cab.
I guess we also have to assume the PO correctly installed the decoders and they did work.
https://ncedcc.zendesk.com/hc/en-us/articles/202353705-Cannot-Read-CV
Are you trying to read the CVs with the locos on the main, or using the programming track option? You cannot read back CVs on the main.
These may have been part of a consist. On both locos, program CV19 to zero. If there is a value other than zero in CV19, then the locos will only run on the consist address.
Then before wasting any more time put one of the locos on the track. Make sure that you have no other locos on the track or else you will program all the locos the same. Make sure you set the PowerCab to the program track mode. Then follow the program track programming menu.
Are you sure that the locos have a decoder? Did you try running the locos on DC to see if they willoperate? Note that you will need a different power supply setup for this, as the PowerCab does not have a DC output.
You can also try resetting the decoders. If the decoders are really NCE, enter a value of 2 in CV 30: https://ncedcc.zendesk.com/hc/en-us/articles/201489365-Master-list-of-Decoder-Resets-by-manufacturer-
I tried at first using a test track. Basically was just 2 sections of straight track by themselves. 1 engine at a time. Thats when i got the cannot read cv message. i was using the program on program track option. Then i tried the main track option using number 3. The lights come on and off remotely now on both engines but they will not move. That’s where I stand now.
Might need to open them up, and see if a wire might’ve broken loose. Shippers aren’t exactly known for being “gentle” with packages.
Yeah that’s what I was thinking too. Also when I hit direction the light changes to rear. I have never installed a decoder so I will have to find a video or something to know what I am looking at. When I left the hobby DCC was way out of my price range and now that I am acquiring stuff again I had to pick this up. I’m sure I will get the hang of it. Also doesn’t help that I don’t have a layout to mess around and learn the quirks of dcc on. I ordered a Kato unit with dcc so I will test that one too when it comes.
Color code for decoder wires is
Red / Black → track (no polarity)
Slate / Orange → Motor (no polarity)
If locomotive is “backwards” (i.e. runs in reverse when you tell it forward), you can either reverse the slate/orange wire, OR tell the decoder to reverse direction (CV…uh… 19, I think)
Blue - function common (positive)
White - Function 0 (usually defaults as light, forward)
Yellow - Function 0 (usually defaults as light, reverse)
Green - Function 1 (e.g. gyra light / MARS Light, etc)
Violet - Function 2 (e.g. ditch lights, etc)
Brown (or striped) - Function 3 (e.g. … um some other light)
No it’s not backwards but thanks for the info. I am wondering if the contacts aren’t making good enough contact with the wheel base. When i nudge the engines on the track the lights flicker also. Ibreax something about adding a thin layer of solder to them?
That’s not what I meant.
Sounds like at least red, black, blue, white, and yellow are all connected properly. That leaves slate/orange as suspect (since the loco isn’t moving).
The comment about “backwards” is simply in relation to when you solder the orange/slate wires – if you have them on the wrong motor poles, the decoder will think it’s going forward (and light the front lights), but the locomotive will travel backwards. So either you swap the wires, or you swap the CV to tell the decoder to spin the motor the other way.
There are lots of youtube videos on decoder installation. A decoder reset won’t hurt your decoder if there is a loose wire and you don’t have to open the shell.
Decoders sometimes go insane for no obvious reason. That ranges from total amnesia to running real slow to other anomolous electrical behavior.
As in reset you mean option 7 correct? I believe I tried that also.
To reset your decoder:
  1. Press the PROGRAM button 4x to enter programming track mode
  2. Press “2” to access your CVs
  3. If it’s a NCE decoder then enter “30” (to access CV30) then “2” (for the value of CV30). Other manufacturer decoders generally use CV8 and “2”.
  4. Press ENTER than exit programming mode by pressing the central red emergency button
You may need to lift your locomotive off the track to restart your locomotive. Enter address 3 to see if the reset took.
ok thanks. Ill give this a shot tonight when I get the kids to bed. If it doesn’t work I pulled the body off the SD-9 and will add a bit of solder to the decoder contacts to make sure it is making good contact.
ANd while you’re in there trying to do the rest, also set CV19 to 0. If they were once in a consist, they woudl also behave like this.
Thanks Randy!
