Here is where I truly am lacking in knowledge I have never done anything other than 2 wires to the track and acc. power to my turnouts and ran in conventional mode. My new layout will be totally command control. First let me give you a breakdown of what I will have also I only intend on running Lionel ,Atlas and K-Line motive power with TMCC
2 levels with 2 mainline loops on each level and a yard on each level.
Level 1(freight)
Outside loop- 49 feet of track, 2 turnouts
Inside loop- 99 feet of track, 9 turnouts, 13 un-couplers and eventually an array of lionel trackside operating accessories.
Level 2(passenger)
Outside loop- 57 feet of track, 2 turnouts
Inside loop- 102 feet of track, 7 turnouts, 13 un-couplers and 14 to 20 lighted passenger cars.
Power- I plan to use 4 180watt powerhouse power supply 1 for each loop and 1 BW80 (for the turnout switches I hope)
Some of the questions I have (and I’m sure there will be many more as I get deeper into this project) are.
Do I start my buss wires at the TMCC Direct Lockon and then make my various connections between my tack and the buss?
What distance between drops to the buss wire.
Do I need blocks with total TMCC operation
What is the best controller for my turnout switches
I really need help in this area guys so Thanks in advance-papa
Building the New York Pennsy & Ohio R.R. (Texas Division)
One paycheck at a time!
You don’t need “blocks” with TMCC, but you do want to break down the track into “Power Districts”. Figure out how much power you want to pull from a given district and set up the “bricks” accordingly. The command signal is carried as a radio wave so drops are not an issue as far as command control is concerned. They are a concern for making sure you have adequate power to a given block/district. SC-2’s work well for controlling switches. I’ve had very good luck powering the SC-2’s from a seperate dedicated power source, not from the wall warts and not from track power.
The only issue you may run into is the two level track. Make sure you have a good earth ground for the Command Base and a secondary forced ground plane for the upper level of track. The TMCC signal could be viewed as a sausage casing field around your track. It project under the track as well as above it. When elevated tracks cross, the signals can get messed up. Placing a piece of wire by or under the upper level and running that back to earth ground will force a secondary ground plane and minimize interference between the two levels.
