I was wondering if anyone could describe how I can wire in an old #154 crossing flasher (the one with three wire connects not two) to a fastrack layout…
I have an activator pack setup, I believe that is part of the puzzle…
Any help would be appreciated…I am a newbie so simple explanations/solutions would be helpful…
I’m pretty sure it’s outlined in Peter Riddle’s book on wiring your Lionel Layout either vol1 or 2. I will look it up and report back in case someone else doesn’t post before then. The crossing gate was meant to work with a “contactor”, a horrible piece of equipment. The contactor uses weight to close the circuit and activate the accessory. An insulated rail section is more reliable.
I mention this on the other post too. I just happen to be reading a article from January 96 CTT and they describe using a relay system that should work well with the fastrack for the 154. I will try to scan the diagram, if I can’t, I will give a detailed description.
Dennis
OK, reading from the article (I don’t want to start problems with posting others work directly). Anyway, the materials as follows:
12 volt DC .1 to 10 second Timer Relay.
12 volt AC double-pole double-throw Relay.
Relay socket
Timer socket
This has the timer circuit for one grade crossing with the flasher and gate, but you can adapt for most set ups.
mount the timer socket onto a piece of plywood. add the two terminal blocks. Next, run a wire from the DC outputs on the transformer to posts nos. 2 and 7 on the relay socket.
solder the 12 volt AC supply wire to the rail. Run the other AC wire to screw B on the relay socket. Run a wire from screw A on the socket to the uninsulated outside rail. Wire screw posts 4 and 6 on the relay socket to each of the tremirminal blocks on the timer board. Then run a wire frim each flashing lamp to screws 7 and 9 on the relay socket. Now hook the third, or common terminal on the flasher to the 12 volt AC power supply on the MRC pack. Complete circuit by running wire from the other side of the AC-power supply back to screw 8 on the timer.
The parts numbers are from a company called “Digi-Key” in MN. PHone 800-344-4539
National Controls CKK-00010-446
Porter & Brumfield KUP11A15-12V
Porter & Brumfield 27E121
Porter & Brumfield 27E122
Let me know if you need the page emailed privately, again, don’t want to cause legal problems.
Hope this helps,
Dennis
Hello Scampana! Lionel Makes a section of Fastrack that is compatible with regular O Gauge Track. Your best bet would be to buy a section of this track and connect the Three Clip Lockon for the Highway Flasher to this Track and you’re all set.
Scampana, Keith, et al., You could also just get one of the new photo sensors that would work just like the lockon, but it would not be realistic. the article described above is for a timed flash sequence.
dennis
