As a newbie to DCC, I’m ready to order some decoders.
I get conflicting answers to the following key question: back EMF or not?
My DC power packs have a similar compensation feature which works great at keeping speed constant despite changes in load due to grades. In straight DC, I have only operated multiple units using locos with the same motor and drive train and this, too, has worked fine.
So should I use back EMF decoders in the following situations or not:
Steam loco that will be consisted only with locos with the same motor and drive train.
Steam loco that may be consisted with non-matching locos.
Diesel loco that will be consisted only with locos with the same motor and drive train.
Diesel loco that may be consisted with non-matching locos.
I’ll ask specifically for recommendations on the following:
My new Athearn-Genesis A-B-A F7 set that will always be consisted together.
My Precision Craft Models Y6-B that probably will not be consisted.
I’m starting with DCC-ready models and the simpler the install, the better.
Thanks in advance for responses.
