Help with frozen axle on MTH PCC Trolley
I bought a PCC car and the wheels connected to the motor (via a screw) won’t budge. The axle rotates when not connected so does the screw/drive mechanism. Once I put these 2 back together–the wheels/unit is frozen. Wheels won’t turn a tad.
Anyone have any ideas?
Thanks
Dan
What you describe is called a “Worm Gear Drive”. The motor turns the “Worm” (screw)(can be steel or nylon) that spins the “Gear” (usually brass or nylon) . This is considered one of the best forms of motor drive, both in models and industry. In most cases, the Worm/Gear is considered “locking”, you can not turn the wheels without power to the motor. In most cases a “flywheel” is added to the motor shaft to smooth operation and provide momentum.
The worm should be riding centered on the gear with a few thousands clearence (not bottomed out) and turning the motor should be free and easy.
