I just purchased a Northeastern Scale Models kit and could use a little help building it. I have built a few Branchline kits with good results but this is a bit more challenging. My questions are as follows:
The instructions call for gluing the clear acetate window glazing to the plastic windows. My attempt on old kits often ended with a nice glue smudge in the middle of the window. What is the preferred glue / technique?
This kit comes with what amounts to a sheet of paper with lines on it for rolled roofing. I know to cut the sheet into strips at the lines but what is the preferred adhesive? Other kits have had a peel and stick, these do not.
On a separate note does anyone know where I can get John Deere Green paint? Does Pollyscale make it?
Actually, I just bought some John Deere green paint at ACE Hardware. They make it in their ACE brand paints. Matches up pretty well–painted a John Deere bush hog with it and it looks pretty good.
Get yourself some canopy glue. It still is good to be as neat as possible, but this stuff dries clear in case you can’t. Makes things almost idiot proof – I should know[:)]
Sounds like you cut the sheet into strips. Best to do this first, then paint, that way the edges get painted, too. Another method is to paint, then cut, then run a permanent black marker or anything that’s close to matching the paint and paint down the edges, coloring them. It’s so thin the match needn’t be exact.
Microscale makes a product called Micro Kristal Klear that will glue the acetate without leaving a smudge. “It will not cause crazing of clear parts” to quote the label on the bottle. It can actually be used to glaze small windows by itself but it does not make a particularly smooth window.
As far as gluing the roof down, I would suggest using basic white glue diluted a bit to make it easy to brush on.
MKT or Reading green w/ a touch of yellow seems close enough to me.
I would suggest sealing both sides of the thin wood first. Even though there are many products to do this, I would reccomend spraying w/ a laquer. Applying a water base clear could warp the panels. Deft, although very expensive, would be a great product to use. Dries in minutes. will take all sorts of glues, white, yellow, Ambroid, Ailene’s tacky, CA ect w/o too much glue apsorbtion and causing a weaker bond.
Depending on the window, you can wait to glaze until after you have installed the frame in the wall. Cut the glazing over size and there should be plenty of room on the edges to glue without getting any on the window surface. I some times use Aileens Tacky glue for this because it has a flexible bond and pretty good initial tack.
If you have to apply the glazing before installation in the wall, a very fine bead of glue on the back of the frame only around the perimeter and careful placement of the glazing should yield good results (this may take some practice). Most smudges come from glue on the fingers, too much glue or moving the glazing after it contacts the glue. BTW: make sure that the frame and glazing will fit through the hole in the wall if you glaze them this way. Often times any extra on the glazing will hang up the installation of the window.
Rolled roofing: The biggest issue here will be getting a smooth application with out warping or bubbling. I might try rubber cement. Any water based glue may wrinkle the roof paper as it dries. I have successfully used white glue with weight on the roof wile it dried (I’ve also had problems with wrinkling using this method) Regardless, you will want to brace the back of the roof to keep it from warping later. You might also consider replacing the supplied materials with stuff from BIS or others that make rolled roofing materials.
John Deere green is available form Badger I believe as well.
Good luck with the kit and don’t be afraid to do over and to change things if you see a better way of doing something.
I should have thought of this with my earlier response regarding the paint.
I have seen use of very fine grit (400 or 600) wet/dry sandpaper, cut into strips and glued down, to simulate rolled roofing. For glue ou might consider a very thin layer of caulk.
I assume that you know that water will warp the wood. One can get sheet shingle roofing from Walthers. This is far superior to trying to cut strips. I doubt that I will ever try to assemble a Laser Wood Kit again. Too much strain to get the pieces together. I prefer plastic kits. Perhaps, good old Testor’s glue that one uses for assembling balsa wood aircraft would be useable. I personally like to use translucent plastic for the windows. Interior light is evenly spread out. I apply sheets of this plastic as one of the last steps in construction. Brushing water on both sides of large pieces after painting them, and applying a weight, keeps warping to a minimum. Bob Hahn
This Grain Bin has a paper roof. The instructions called for using rubber cement. I did and it went on fine with no bubbles or other issues. I used a Krylon black spray can followed with a light misting of Krylon Gray primer.
I would recommend painting the window frames and perhaps the entire structure BEFORE glazing the windows. Otherwise paint always gets on the glazing and looks sloppy. I use clear polystyrene plastic for glazing, I cut it to fit and use plastic welder to glue it to plastic window frames. Just a drop, applied to the back of the window with a very fine brush, or the eye of a needle, NOT the bottle top brush, gives a good slop free bond. Capillary action sucks the watery plastic welder in between the glazing and window frame. I get by clear polystyrene from supermarket sandwich boxes or Entemann’s pastry boxes.
If the glazing material furnished with the kit is acetate, heavy duty cellophane, then all bets are off. The plastic welder only works on styrene. I would skip the acetate and find some clear polystyrene.
Thanks for all the great ideas. i have ordered the John Deere paint from Walthers. I amgoing to get either some canopy glue or Krystal Klear for the windows. David - Thanks for the idea for the styrene. I tried to convince my wife that it was in the best interest of my modeling skills to go out and get a box of the Entemans Super Cinnamon Buns but so far no luck!
First off laser kits are not hard and a lot of what they say about sealing the wood is bull. Just use gel ACC to glue it together and make sure you use a lot of bracing (sometimes kits don’t come with enough or none at all and without the bracing you will have to worry about warping big time). Now assuming you braced the kit properly, any craft paint will be fine for painting it!. As far as the roof, some like a double sided tape by 3M and swear by it, I like yellow glue and a small paint brush (yellow in case you use acylics in the finish, very water resistant. As far as the windows, canopy glue is fine, I have been known to gut a thicker peice of plastic and use clear latex caulk to adhear it.
rrebell, I have to agree, the laser kits are fairly easy. Actually I find them easier and much more enjoyable then plastic kits - personal preference I guess. You mention a concern about warping without bracing. I have completed a couple of kits without bracing simply because I did not know about it. Thus far everything seems good. Is the warping something I may need to worry about months or even years from now? In part I am thinking that N scale may be a bit more forgiving than the bigger scales simply because the parts are smaller in the first place.
A timely topic for me. Just starting a laser cut wood kit (passenger station) by Branchline Trains. Will face the same questions eventually(except that the roof is a plastic sheet with adhesive backing). Before getting to that stage though,I need to glue the four main walls (wood with adhesive backing facing outside) from which all the other structures will be attached. The two longest walls are warped. Don’t know if I can flatten them with techniques-like steam-I’ve read about in the past (especially with the adhesive). Planning to build a fixture to clamp the corners individually or all four at once as well as add bracing (corners only or diagonally?)so that the completed assembly will not twist and thus prevent the other parts from fitting properly. The trick will be to keep the walls square and the bottom flat. Any suggestions would be appreciated (particularly about the bracing).
Will the walls warp over time?? Depends. Most of the stuff I built w/o bracing has warped. Maybe you will be more fortunate.
As for bracing walls on corners and diagonals…More the better!! The only trick is working around windows…Search the forum for posts by Bob Grech…He did a tutorial on building structures that had some good examples of interior bracing.
