Help with layout for a huge room
Hello all. This is my first time here. I used to have trains as a kid (HO and N) and built constantly changing layouts for them on a 4x8 plywood sheet in my parent’s car port. Would even run them with some cars on fire etc.
Those trains are long gone and now I teach art at a high school. I was given the old shop room as the new art room and want to build a track that circumnavigates the room just over the doors. Also I want to have a way to have the trains descend and ascend to and from lower tracks. Maybe make a helix? A figure eight?
The trains will travel through different environments like a big faux tree, faux stones, a glowing mushroom forest, a waterfall, etc.
I am thinking that O is the best size because of the size of the room. Also because of the much better smoke production of locomotives in O over HO.
I currently have a Lionel diesel set in O (Norfolk Southern) but will be looking to get a couple of steam locomotives that can produce good “smoke”.
Any advice is greatly appreciated.
I calculate about 180 feet of track for the upper track. Have to determine switches, curves etc. Also have to determine how to do the grades of 2%.
Will I need some kind of booster for the electricity on that much track?
The room is basically 57 feet long by 40 feet wide, though there are angles etc. on the walls.
Welcome to the MR Forums! [#welcome]
When selecting a scale, remember that the larger scale you choose the larger radius curves your trains will need. If you are considering a helix to bring trains down from the upper loop to eye level, in HO that helix must be a minimum of 40" across (to the outer limit of the benchwork, with an 18" radius), and larger would be more reliable. In O scale, toy train track would allow a tighter radius curve, but you’ll never get the grade separation you need for a helix at less than a 48" radius. So you’d be looking at losing an almost 9x9-foot chunk of your classroom to helix. Since the trains shouldn’t be the focus of a working classroom anyway, consider sticking to just the track above the doors. If you want trains at viewing height, build a separate shelf layout rather than trying to connect them.
Welcome to the forums!
This sounds like a very interesting project. I hope you can post some pictures of your progress. Keep us up-to-date with how it goes!
[#welcome] to the Model Railroader magazine discussion forums. Your first few posts will be delayed by the Kalmbach Media moderators, but that ends soon enough, usually after a few posts. Please stick around through the delay and become a permanent part of the discussions.
I cannot offer much help to the questions you are asking. Track planning is not my strong suit.
However, I LOVE the idea of an O scale train going through a fantasy mushroom forrest with train cars decorated by creative high school students.
I hope you return and share pictures.
Good luck with the project.
-Kevin
What a great project! Lionel stuff is pretty much bullet-proof, but your wallet will suffer from it. You might be able to integrate a long grade instead of a hellix. Also, you can make two wyes and a long single track for continuous running. The 3 rail was basically designed for that purpose. There are a few options with respect to radius. O27 is pretty tight, but there will be less options for the locos and rolling stock.
Good luck!
Simon
Will there be students in this classroom? I think you should carefully reconsider the “smoke” idea. That stuff can be pretty noxious, especially to those with asthma and/or other allergies and breathing difficulties.
Depends on whether the OP like toylike trains or more to scale trains. True you could put an O scale layout in the large room he has but HO can surprisingly eat up a lot of space, especially if you want to run long trains. I recommend going with HO - there is a large selection as well.
For above door level?
No. For his large room. [;)]
I read it as there is only one room:
Just keep in mind that O scale locos can be quite heavy, especially the large steamers. The health and safety department might not like that kind of equipment rolling above your students’ heads [:)]. You can put some kind of transparent railing, but you won’t see much of it anymore at that height.
Simon
