help with new athern genesis
bought a new athern genesis 2-8-2 . It still has the dc chip on it can’t seam to get it all to fit in tender so i can get the engine and locomtive to hook together and ideas ? do i need to take tender a part ? also what brand dcc chip should i install im also hopping to install sound to not sure if it will be all at one or at seperate time thanks alot for your help guyes
ray
Hi Ray;
Telephone Tony’s or Loy’s for specific advice.
There are many decoders that will fit, depending on the features you desire.
If you are talking about the dummy DCC plug that comes installed on the pigtail, just angle it theu the big hole in the front of the tender. If it is indeed a DCC chip, then you may have to remove the tender shell if it won’t go thru the hole.
Save yourself some grief and remove that stiff sheath off the wires going to the chip socket before you start to suffer derailments from it.
well that sounds simple enough!
