Help with road colors
Hi everyone, hope the summer found you well! The trouble I am having is choosing a color for the roads on my layout and I need some advice and guidence. So far I have tried Woodland Scenics Asphalt and it seems a bit dark, tried to add some white and to me it does not look right, then I tried WS Concrete and again to me it looks way to beige. Now I think a lot of what makes a road look good is in the weathering which is a whole other issue, but I am afraid if I don’t start with something close no amount of smudgeing and dry brushing will help, so do you all have a good formula you could share with me? any info would be great and thanks for reading.
PS when I try to use spell check it says I need to download ieSpell, has anyone done this and did you have any trouble with it?
Chuck.
What color will look best is going to be a function of the type of lighting you are using. You will have to experiment some to fnd the right shading.
