Hello All,
I too use Woodland Scenics form roadbed on top of an extruded foam base.
Pushpins won’t have enough length to bite into the foam through the roadbed, no matter what material you use.
To attach the roadbed to the base I use General Electric Silicon I or II Clear Caulk. The difference between them is II is rated, “Rain Ready” after 30-minutes.
For some, the smell of curing silicone caulk will be a deal-breaker.
As others have recommended, 2-inch “T” pins will provide the needed length while the roadbed cures. You can find them online for less than $10.00 for a pack of 100.
After putting down a thin bead of caulk on the roadbed I use a plastic 1-1/2-inch putty knife to spread the caulk in a thin even layer. Another advantage of this caulk is it cleans up with water.
For curves, I cut the roadbed down the centerline.
Then I mark the centerline of the curve on the foam base. I then put a line of “T” pins; approximately 2-inches apart along the marked centerline as a guide.
Next, I put down the pre “glued” roadbed and snug it against the “T” pins on the centerline.
Then I use more “T” pins to hold the curved sections of roadbed in place and allow to cure for 24-hours.
After the roadbed has cured I remove the “T” pins and put the track down.
To hold the track in place I use #19 x 5/8-inch wire brads. I use the silver-colored ones.
Brads will hold the track in place for testing and tweaking.
If the roadbed/track needs to be completely re-aligned you can simply pull up the foam roadbed, rub the silicone caulk off with your finger and begin again with no damage to the roadbed or base.
After the track/roadbed is set I
