Help with wiring first total TMCC layout
Here is where I truly am lacking in knowledge I have never done anything other than 2 wires to the track and acc. power to my turnouts and ran in conventional mode. My new layout will be totally command control. First let me give you a breakdown of what I will have also I only intend on running Lionel ,Atlas and K-Line motive power with TMCC
2 levels with 2 mainline loops on each level and a yard on each level.
Level 1(freight)
Outside loop- 49 feet of track, 2 turnouts
Inside loop- 99 feet of track, 9 turnouts, 13 un-couplers and eventually an array of lionel trackside operating accessories.
Level 2(passenger)
Outside loop- 57 feet of track, 2 turnouts
Inside loop- 102 feet of track, 7 turnouts, 13 un-couplers and 14 to 20 lighted passenger cars.
Power- I plan to use 4 180watt powerhouse power supply 1 for each loop and 1 BW80 (for the turnout switches I hope)
Some of the questions I have (and I’m sure there will be many more as I get deeper into this project) are.
  1. Do I start my buss wires at the TMCC Direct Lockon and then make my various connections between my tack and the buss?
  2. What distance between drops to the buss wire.
  3. Do I need blocks with total TMCC operation
  4. What is the best controller for my turnout switches
    I really need help in this area guys so Thanks in advance-papa
Building the New York Pennsy & Ohio R.R. (Texas Division)
One paycheck at a time!
Papa,
Post this over on the Classic Toy Train Forum. You’ll get plenty of help there.
Welcome Aboard!
