help
i cant get my zw (new) too put my trains in neutral…goes forward …reverse,but when i pull throttle all the way too zero train doesnt stop…any help ?
Sounds like you have at least one wrong terminal hooked to the track, and you have selected a constant voltage pair of terminals. Try reviewing instructions. Most Lionel transformers have clearly marked …like “0-16 volts” range.
Good luck & reagards / Mike
