OK, after mucking around with planning a layout for the past several years [:I] I think I finally have it. Please be as picky as you want. (And from what I’ve seen, some of you can be darn picky! [:D]) Any suggestions and criticisms are welcome! Let me give you some background. This is HO, and the layout size is 9 x 22.5 in my attic. Total attic space is 9 by about 40, but hey, I have to put the Christmas decorations somewhere, and I don’t want to bite off more than I can chew! This will be built on 2.5 x 8 tables, plus the two 4x4 tables so I can move it some day. (It’s a rental house.) I’ll be constructing with my nine year old son (although I think he plans to mainly wait until he can run a train). I will mostly be operating by myself, along with my son on weekends and perhaps a friend or two of his.
As you can see, it is essentially a folded dogbone with the end loops stacked. The yard is in the middle of the dogbone, with the upper portion (about 6" elevation) running up a long grade behind the yard. Those are 2 hidden staging tracks under the grade. There will be a couple of more on the other side, but they cluttered the plan. The greenish area is the upper loop, and the sandy color is the base level. Gray track lower loop, green track upper. I also put in a short, steep branch to a couple of small mines or logging areas. Setting is Eastern US, with coal action and a port. I know that might be the king of compression, but it’s what I want! OK, enough about this spaghetti bowl, tell me what you think. Oh yeah, my modeling skills range from beginner to not very much better!
Thank you for any assistance.
David
