still a newbie. Any help will be highly appreaciated!
When I use wire leads to test the motor directly, the motor runs fine with no spark. But when I hook up a tender with drawbar it runs hesitate at best and there seems to be spark in the motor, sometimes on the drawbar. I don’t see sparks when I
use wire leads to test the motor directly.
When I examine the electrical path, it seems the motor’s two wires, one from the tender drawbar and goes to the headlight, and another soldered to the metal weight (but I don’t know where it picks up electrcity from the wheel. See below. I looked at HOseeker, but the diagram does not seem to have the wire goes to the headlight.
Check the Brushes on the Motor and clean the commutator, the older rivarossi pick up power from the engine frame directly, (the chasis is not insulated).
drawbar does have a spring, it relies on the tension to maintain constant electrical contact with the pin on the tender, it is there but I can’t say it’s too good.
It does pick up power from the engine metal weight shown in the picture (is that the frameyou are referring to?)
Do you think the spark comes from dirty brush/commutator? I asked this because when I test the motor directly using 2 wire leads it seems to be work fine w/o sparks
Does it require motor dissembling? The motor is square shaped as shown in the pic, it seems the brush/commutator are inside w/o good access, how would one do the cleaning? Thanks!
Sounds to Me like You have a bad wire connection somewhere. Could be a corroded contact point, intermittant contact, hence the spark. Clean all wire contact points, with CRC 2-26 Electrical lube and cleaner. You may even have a wire barely making contact in a soldered connection. That is a fairly old engine and the wires/connections do corrode over time.
BLI released 2-10-2’s back around 2014/2015, they are equipped with sound and DCC. If I were you, I’d just get a new locomotive rather then trying to fix an old engine that will fail again down the road.
How old is that locomotive and when did you get it?
Rather than repeat earlier comments, let me invite you to Jeffries diner where we talk about model railroading and some off topic subjects. Hope to see you there and tell FLO to put your meal on YGW tab.
Lost Rivarossi steam engines get the electrical connection from one side of the engine and the other side of the tender. I find the drawbar is pushing the tender off the track and that is causing the hesitant behavior. What do you need to do is make sure the drawbar is not causing this tension and also put some more weight in the tender I also put washers between the tender body and the trucks, particularly in the front.
Well it possible being that these Riviarossi engine are made in the 70’s and 80’s, it might help to clean the motor up. This link show one of the fourm members that have disassemble one of these square motors.
Though I don’t know much, I might be able to shed some light on this subject. I would immediately take the tender out of the equation. Rivarossi tenders were almost always made out of plastic with no electrical connection to the locomotive. Why rivarossi developed them with metal draw bars as well as tender hooks, I do not know. The 2-10-2 that I own is made by rivarossi and I know the motor I have likes to lock-up. I have no idea why. when it does this, the ball bearings then establish a full current from the positive rail to the negative. This would cause sparks and poor running your describing. I haven’t found a natural fix for this, but i’m planning on remotoring my locomotive and seeing if that fixes it. If not, the drawbar might be coming into contact with the metal plate holding the rear truck. This scenario would cause the same sparking and failed running. Just an idea. I hope the best of luck for you.
All older Rivarossi locomotives need some TLC, I have twenty older Rivarossis and after a good cleaning and tweaking they make great runners. All of the above advice is good, be patient and keep after it and you will have a good runner. As stated above the tender is the Rivarossi weak point. They need some added weight and CRC2-26 lube at the bolster. Make sure the spring between the truck screws and trucks are in place. Bend the drawbar spring to insure it makes good contact with the tender tow pin.
Edit:
Check for rust at the rivet in the drawbar where the wire spring attaches. There should be a solder tab on one corner of the motor going to the ground side brush held in place by a motor screw, I had one that had a very fine crack in the solder tab.
I don’t have a 2-10-2 but a Canon EN-22 can motor or Faulhaber 2224RS work very good in the Rivarossi articulateds.
LEOFUTURE, I’m having similar issues with a Rivarossi Heisler (3 truck) so thank you for brining this up!
Another issue I’m having is that there is a smell like an old '60s TJet slot car. That smell for the slot car meant oil on the commumator and/or brushes or a dying motor. Does that same thing hold true for the Rivarossi motors?
I know for the bunch of Rivarossi’s I have that they tend to build up dust inside of them causing them to smell terrible after a couple of runs. The solution I learned for this is to just run them until the dust burns out. It happens frequently so its a good way to tell wheather or not its been run in a while. No damage to the motor ever occurs unless someone tries to use a cleaning agent to get the dust out (Wouldn’t advise as it usually ruins the motor) After a while the motor will have burned the dust out and will stop smelling and run as it had before. This run time can take anywhere from a couple of seconds to (My longest case) ten minutes or more. No motor I have ever done this to has burned out or shot, all of my rivs are now running just fine, though I may need to go back and dust run them again. Just food for thought.
If this doesn’t work, then there is more than likely something in the motor that doesn’t need to be there. I’ve heard some stories at the club about some people putting sorts of conducter liquids in motors before and that causing the motor to smell terrible as it was burned by the heat produced (Suprised more damage didn’t happen because of that). If there is some sort of oil or liquid in the motor, the dust run trick should still eventually burn it away, though it will take much longer as it is much more resistant than dust.
Thanks, Mantua Man. I only ran it for about 30 seconds before smelling the odor at which point I stopped running it. I bought it off ebay and the seller said it has been in storage since he bought it new. Not sure if I believe it, but I have no reason not to. lol I’ll give it another run and see how it does after 10 minutes or so.
Is one of the tender trucks reversed, assuming split pick up between the locomotive and tender? Could one of the wheels in the tender truck be reversed possibly, causing an intermittant short if tender trucks are not making good contact?
I would find it hard to have the trucks and/or the wheels being reversed; heres why. On rivarossi 2-10-2 models the tender is a 12 wheeled vanderbuilt. The way rivarossi produced the tender trucks is so that they are mounted on once side of the truck, not the middle. This would make finding which end of which much easier as well as making it harder to reverse the truck poles without diss-assembling it as they would stick out the sides and have to pass through the mounting ladders.
Switching the wheels around is possible, but very difficult. In the rivarossi design there is a large piece (Metal or plastic depending on the year) holding the wheels in place. If someone decidided to switch the wheels around than it would most definantly leave some remenants behind such as scratches, bends, and dents in the plastic/metal.
I tell you, deciphering the problem with this loco is tricky. I spent the weekend looking all over mine and I cant seem to find anything that would cause a short. Very intresting.
As for Bibbsters post, I can almost for sure say it is the dusty motor poles. If its been sitting in open, or even closed storage, for a time than it will definantly collect dust. Depending on how long its been sitting it can build up many levels of dust. I have an old Varney loco that I’ve posted about, and when I first ran it, it began smoking because of all the dust in it. I took some tweezers, an air duster, and some time off my hands, and it runs much better now (Especially without the retched smoke[:-^]). Just running the rivarossi loco should clean out the motor. As I said it could take varoius amounts of time depending on how much dust
Boy, that an OLD slugger! You say that it doesnt spark at the motor when you hook leads up to it, but does spark at the motor when you hook up to the other current delivering areas.
That could mean that when your hooking up to the motor directly, you could be adding pressure to the brush springs, improving it’s contact momentarily. That would indicate, as others have mentioned crud on the commutator surfaces, or that they have oxidized ( turn brown instead of shiney copper color)
It’s hard to say how to service it without more pictures. There are replacement motors on ebay, i dont know much about them. That old Rivarossi motor is probably noisy too, huh? I think Mel has replaced motors in a few Rivs. He’d know. Dan
For those that are comenting about older stuff, most older stuff can be made to run just as good as new stuff and can become just as detailed. The question is, is it worth the effort, that is for each of us to deside on their own.
