hey
hey check this out please and give me a bit of advise on which plan is better
many thanks and for more info read the topic on the site
thanks
pavariangoo
Hey Back!! Check What out??
Jeff
The temporary loss of brain function?[:D]
(been there, done that)
Jeff
heh sorry i guess itd help if i put the link in =)
http://www.the-gauge.com/showthread.php?p=171947#post171947
Is this going to be up against a wall or is it going to be free standing??
Jeff
it will be on sawhorses. not on the wall
pavar
umm . could you please clarfiy your question? it will be along the wall and window but not mounted to it.
why do you ask?
pava
It’s only 2 feet wide, so reach wouldn’t be a problem.
Jeff
They look virtually identical to me, except for the additional yard trackage toward the upper right. How can you pick a “best” when it’s 2 of the same?
I’d pick the one on the right if I had to choose.[:D]
Jeff
The one on the right makes more sence, but why would you have a by-pass siding on a siding?(same feature in both plans)[2c]
Reach wasn’t the reason I was asking… I was going to suggest a Divider backdrop running along the middle to make it more of a true walkaround… As far as the two plans go, second one. I like yards…
Jeff
thanks
That’s an idea (I’m not thinking)!
I also agree: more yard space=better
Jeff
oh the 2 sidings on the bottom make a small ladder yard
i do not think trains can turn like that but… I say get a new track plan
Definitely tra***hese two plans. Unless you are modeling a very industrial line, with 2 axle engines… And in your topic, could you make it more obvious what you want?
Plus, with two plans like this, it’s really up to you, and your individual taste.
I like the one wit the ladder on the spur instead of the runaround. That way, you have one less runaround to use, and it could be more of a challenge for operations.
Are you sure you can fit all that in 24" wide? I would use a different CAD program to make sure. Xtra Cad is free and comes pre loaded with Arnold, Atlas and Kato track and turnout parameters built in as well as flex track options. http://www.sillub.com/
Looks awful tight to me is all. If it works, I would go for the one on the right. As posted before, it would make more challenging switching.
I was under the impression this was N scale… Why couldn’t he fit it in his space??
Jeff
Ah, N scale! That would make sense!
I think the sidings could stand a bit of an extension. Not much room for car storage, maybe 1 a siding.
