High amp power pack for DCC
I am new to DCC, and haven’t installed the digitraxx starter set I bot, yet. It is a 5 amp unit, DCS100. I have a 14vdc 24 amp power supply. I also have the 15vdc 5amp power supply made by digitrax. Can I hook up either one to the DCS100, or stay with the 15vdc unit? I only have three locos, and probably should use the 24amp unit for switches, lights, etc. Just wonderin’ if there is any advantage! Thanks, John
You can use either, but you want a 5 amp fuse on that 24 amp power supply to protect the DCS100.
The 14V DC supply is probably on the low side though, you won;t be able to get 15 volts to the track out of that. The input to the DCS100 takes AC or DC - thus it has diodes or a bridge rectifier on the input, which with a DC input will drop about 1.4 volts. With an AC supply, rectification plus filtering capacitors will result in a voltage HIGHER than the nominal output of the supply. The 14V unit would be fine if you use the N scale track voltage setting.
If you reserve the 24 amp unit for lights and accessories - run multiple lines with fuses, do NOT run a single set of wires with 24 amps around the layout - 24 amp at 14V is 336 watts - more than 3 100 watt bulbs - aka hot enough to weld, melt things, start fires. Make it kind of like your house wiring - 14V, 24 amps into a distribution panel with multiple fuses leading to multiple circuits restricted to some lower amp level for safety.
I would just use the 5 amp PS515 power unit. If you use the 24 amp unit, you will need to fuse it or put a fast acting circuit breaker in-line between the power supply & the DCS100. Jim
Thanks To Randy and Jim!! John
Spend the bucks and get a power supply designed for the dcc system you purchased. David B
