High Pitched Hum
I have a moderately large layout of n scale Kato Unitrack. I’m using an NCE Power Pro 5 system. Everything works great, but there is an annoying high-pitched hum, which seems to be coming from the turnouts. Switching a turnout makes no change in the noise. The turnout switches are powered by a Kato power pack not the NCE system. Even so, the noise only happens when the NCE system is on. The folks at NCE felt it was a Unitrack issue. Haven’t heard back from Kato yet—unsure if I will or if they’ll just say it’s an NCE issue.
Anyone else have this problem or heard of anyone having it? Any ideas how to eliminate it?
Thanks
Bob
are the turnouts controlled by dcc or by a switch board? If it’s dcc, then you might want to try a different brand of trackside decoder
Read his post. Controlled by Kato power pack.
I assume these are twin coil machines.
Have you got a turnout you can try on the work bench?
That is a strange one right now.
A short can make a high pitched sizzling sound, it’s one way to track down a short in a DCC system. If it’s just some poor contact causing the short, it might not draw enough to trip the breaker.
