Why are all the high speed lines electrically powered? That seems to be true worldwide, but what prevents GE or EMD from changing the gearing of a conventional diesel-electric and selling it for the 150 mph & up service? There is sort of a hidden assumption here that a line to run it on already exists, but let’s ignore that for a moment.
Diesel fuel vs electricity costs might be one answer; but the cost of catenary seems to prevent the Class I’s from converting their freight lines, so that can’t be the whole story.
Not enough horsepower and too much weight. Take the standard German passenger electric the Class 101, it is rated at about 8800 hp. and weighs just 92 tons, and these are only good for max of 140 mph. The French and Germans feel if you want true high speed (186 mph or above), you have to keep axle loadings below 17 tonnes (18.7 tons US). Otherwise track maintenance costs become uneconomic.
Short time horsepower rating may also be a factor. A 3000 hp diesel is limited to 3000 hp. A 3000 hp electric may reach 4000 hp or higher for a short time when starting.
The GM&N Rebel was not articulated, but used a power car.
The first IC Green Diamond was articulated, with power car:
The first UP City trains (through 1941), and the first CB&Q Zephyrs (through the Silver Streak Zephyr) had what seemed to have been called “power units.” All of these trainsets were articulated. But, I doubt you would have been executed had you called the power unit a “power car.”
High-speed rail in the US does not necessarily mean electric, and the Federal Railroad Aministration actually does research the possibility in a project known as “High-Speed Non-Electric Locomotive Technology”. It’s mentioned in their 5-year plan: http://www.fra.dot.gov/downloads/Research/rdv0202.pdf
I encourage you to explore the documents and presentations on the DOT’s web site to find out more. I cannot find the big document that describes the project in detail. It appears to have been moved (it had been under “Research and Development” section): http://www.fra.dot.gov/us/content/199
The project stalled and of course there is the Bombardier JetTrain prototype sitting in weeds somewhere (looks alot like an Acela but a turbine where the transformer would be).
The problem is that what the FRA is spending is a pittance compared to what the Europeans are spending. Even if the new Administration ups the funding we are many years behind them. Better to not reinvent the wheel and instead take advantage of their expertise in HSR. Any non-electric system has to carry the weight of the fuel along with it which is a big disadvantage. Weight is the enemy of HSR.
One solution may be using dual mode locomotives in and out of stations. We do not know how well the new NJ Transit dual mode locos will work and how heavy they will be. If – ? – the locomotives can take 8000HP under CAT and 4000 otherwise then if stations had CAT installed the full 8000 could be used to accelerate out to some speed and then the diesel take over. Anyone have acceleration curve ratings per 1000 tons (or other value)??
I don’t think that there is any production diesel capable of over 150mph anywhere in the world. The official world speed record for a production diesel is only 148mph (set by a British Rail HST, which only do 125mph in regular service). The Spanish Talgo XXI prototype has since reached 159mph and a Russian TEP80 prototype is claimed to have managed 168mph.
The HST and Talgo XXI are relatively lightweight trainsets of the kind which would not meet FRA specifications, but the TEP80 was a conventional locomotive. I don’t know what it weighed, but even with B+B-B+B wheel arrangements its axle loading combined with the speed must have been extraordinarily tough on the track.
The British HST sets are due to be replaced in a few years, and the contract for their replacement has just been awarded to Hitachi (so much for buying British L). However, there is an ongoing debate about whether building new diesels represents value for money. It has been argued that it would be cheaper to electrify the remaining inter-city
It is time for our engineering minded posters to take out their power charts and figure out how much HP is needed to maintain a certain speed on say a 1% grade per 1000 ton train for various speeds and then addapt that to an amfleet trains. ie can 4000HP pull 7 cars at 80 mph, 5 at 110, 3 at 125 or what is the actual figures? Then we can better argue about the high speed diesels and their value. I seem to remember that the NE corridor NH - BOS always had two F40s pulling the 6 car trains befor the electrification was completed.
I live less than 5 miles from the NEC (in RI) and it was very common to see a single F40PH on many if not most trains. Obviously the speed limit north of New Haven (the old end of the New Haven electification) was much lower in those days. The PC/Amtrak Turbotrain sets did O.C run at high speeds on the corridor…
The quick answer is they are not. Gas Turbine-powered trains run at 125 mph in France (they consider this normal speed) and the RTL Turboliners ran at 115 mph for 22 years on the Schenectady-New York City route, limited only by the track. The RTLIII trains, which Amtrack refused to run, were clocked at 140 mph during acceptance testing near Schenectady. To run fast, unsprung weight must be kept as low as possible to minimize “P” Forces that cause rapid roadbed distruction. Diesel locomotives, which are basically converted freight locomotives, can’t meet this requirement and so are limited to lower speeds.
Bombardier’s Gas Turbine-Electric locomotive weighs no more than the Acela electric locomotive and while it has been limited to 125 mph for basically political reasons, undoubtedly could run much faster. Given the right design and the right track, speed is a function of horsepower and the locomotive or power car does not care whether it is generated on board or comes from far away via transmission line and catenary.
carnej1: as those times I rode that section before the ROW upgrade there was only 1 F40. However the 2 times I rode that segment while they were installing CAT the schedule had been reduced (too much I believe) and those 2 F40s accelerated us to their 110 MPH much faster.
The Turboliners not only have lower axle loads than Diesel locomotives, they have hydraulic drive through Cardan shafts rather than nose-suspended traction motors (OK, the RTL’s have traction motors, but aren’t they feeding the drive system rather than hung on the trucks?)
The proponents of power electronics and electric drives talk about how mechanical drive trains are part of technological history, but if that is the case, why are the Europeans looking at quill drive if not to reduce unsprung mass for high speed operations? And a quill drive is a form of an articulated mechanical coupling between a sprung motor and an unsprung axle, as are the Cardan joints, and drive shafts between the hydraulic transmission and the axle on the Turboliner. As are the connecting rods on a steam locomotive. Mechanical power transmission lives on in railroad applications.
Correct, with the caveat that the French retired the last Gas-Turbine powered trains almost two years ago now.
Further exception is that not all diesel electrics use nose suspended traction motors, both Bombardier and Siemens offer quill drives on the passenger versions of their diesel electric road locomotives as an option. Also the JT42HWs built by Alstom in Spain for EWS in England used frame mounted traction motors with Cardan Shafts driving the axles, these locomotives are rated at 125 mph, quite possibly the fastest EMD powered locomotives.
