I’m looking for a franklin tender truck in HO for a “what if” scratch-build. Wheel and wheelbase dimensions aren’t set, I’m going for the look. Level of detail also isn’t a huge issue, I can add detail if necessary. I’m hoping for something that will give me the look and will roll without constant tweaking. I’d like to keep costs down, so I’m not looking to spend hundreds of dollars on a perfectly good model to scavenge one part from.
I found that PSC has a kit, but I’m just wondering what my other options might be.
The only PSC trucks I have any experience with are their Buckeye tender trucks and while they look fantastic they don’t track very well at all. After putting in hours and hours trying to get them to run without derailing I finally gave up on them. Replaced all of them with Bowser Buckeye trucks and sold the PSC trucks on eBay.
This was a somewhat more workable method of putting an auxiliary locomotive (it would be a ‘booster’ on a trailing truck) on power like a 2-8-0 or Decapod than a Bethlehem type (the one with the outside coupling rods to additional axles, which had augment issues at any particular road speed).
These were essentially near-drop-in replacements for tender trucks – usually lead tender trucks, for dynamic reasons, but either could probably be used. In real life you’d have to arrange for steam and exhaust pipes, a couple of lube lines, and some air control, much of which might not be clearly visible with the locomotive on the track. The gear in the cab might be little more than that required for a nonreversible booster, which in simple form (as for the booster on Frisco 1351) is just a vertical air pipe with a push lever on top.
If this is a pure scratchbuild and the locomotive has no trailing truck, consider ‘pushing’ the Franklin truck forward into the space between the trailing driver axle and the rear of the locomotive chassis, then putting the radial buffer (also from Franklin) at an appropriate pivot to let the powered truck ‘steer’ the rear of the engine chassis as a partial replacement for what a Delta truck would do. That would give you much better riding as well as shorter piping.
For the price they’re asking in the page I linked, it would be hard to imagine the time and effort involved in scratchbuilding a visual equivalent, even assuming that you knew why all the detail on the Franklin truck was made as it is. (And don’t ask me, as I don’t either, without doing quite a bit of additional research [:$])
I probably shouldn’t add this, but you might find more visual interest from a Bethlehem auxiliary locomotive, a model of which was provided with many of those IHB 0-8-0 models offered i
I’m not really familiar with the Franklin truck, but from what I see in the PSC catalogue, it’s designed for use with a booster.
The kit for the truck-only is 3 pieces and, in my not-recent version of the catalogue, it’s $12.50. I’d guess that it’s for modellers who wish to add their own booster details.
The full kit, which includes the truck, booster engine, a pair of steam joints, and siderods for the truck seems a bit vague regarding the price - some of the parts are add-ons, and the siderods don’t seem to have a price, other than that for the 3-piece truck kit.
I’m sure that the current prices are considerably higher, but if you need a four-wheel truck with a booster engine, it’s not likely going to bankrupt you.
I don’t think a Franklin auxiliary locomotive has siderods like a Bethlehem. It’s a geared engagement with a fixed gear on one axle, like on a typical trailing-truck unit. As such it would have little added unsprung mass on the tender wheels, and no unbalanced quartered cross-balancing issues, so could provide useful low-speed TE combined with no reduction in road speed.
I wouldn’t be surprised to find a detail castings company making both types of truck, though. Or that Franklin did make a variant to “compete” with the supposed adhesion of the Bethlehem type.
The siderods are really what I’m going for, and the Franklin has them, it just isn’t evident in the 3-piece truck that PSC offers. They have a full kit (#3334) that includes the wheels and booster, and the (2017 list) price is not a problem. That’s probably the way I will go, assuming I can get one. I was just thinking if there is a ready-assembled solution (a repair part or something) for not too much more, I’d go that way and avoid the hassle of building it.
Any two-axle booster with side rods would work for me, really, I’m just not finding anything else at a reasonable price. Plus, I wouldn’t feel bad scavenging a truck off a scrap pile model, but I don’t want to kill a perfectly good model if I can avoid it.
As if getting your eyes on this wasn’t more luck than a guy could hope for!
Thank you so much for the great resources, Ed!
Finding the parts is at best half the battle. Info on how to put them together to conform is a whole other set of problems and just made them way easier.
The problem is that you’d have to keep watching eBay for an IHB model that has one (not all of them did) and then (after utilizing the booster) try to resell it either as a ‘parts unit’ or with replacement trucks. If it helps, I was in the market for one to ‘re-create’ a conversion I did many years ago, and it seems that prices are reasonably high for locomotives without the specific booster truck – but also surprisingly low at times for the O-scale kits complete with the parts to make one in that scale (which you could use for patterns in making a smaller version, or to scan for resizing and 3D printing)…
Lots of models are becoming available with “rotating end-cap bearings” and Rivarossi made the U-25-Cs with rotating end caps. There may be enough of a pin projecting the axle end you could fit the eccentric on to it.
Maybe you could figure out how to 3D print the eccentrics and side rod (at the exact centers) and go from there?
Sometimes you can contact a designer and ask them to modify a part or dimension for you. If you convince them there is a market they might jump on the opportunity.
The Shapeways parts are apparently for the ‘original’ tender booster prototype, the one described in Railway Mechanical Engineer vol. 73 p.145 (the full volume is available to download as PDF through Google Books) that was developed by J.A.McGrew and J.T.Loree. It turns out that there were a raft of interesting patents granted in 1925 for various aspects of this (which as I suspected was for use with locomotives with no trailing truck, here large 2-8-0s):
By McGrew alone: 1,580,838; 1,605,367; 1,605,366
By McGrew and Loree: 1,580,211; 1,580,837; 1,609,964
Some of these were assigned to Bethlehem, which identifies this as the genesis of the ‘auxiliary locomotive’ and not the Franklin design.
The improved version by McGrew, with a proper reversing engine to clear jams, is 1,742,610 (Jan 13 1930)
It should be easy to construct an appropriate truck (well, easier than without the reference) using the drawings and information in these patents.
Interestingly, there is a case concerning booster design that was appealed (and lost by McGrew/Loree and Bethlehem) at about the time of that last patent – Ingersoll v. Delaware Hudson Co. – over some details of the NYC version of the booster (see patent 1,383,633). In this decision is an interesting history of booster devices and their advantages and drawbacks that I have not seen in any railroad-related source or discussion, and the OP might find some of this information useful.
I don’t think there is any practical way to use thin-end wheelsets for quartered counterweighted rods, especially not if the parts are 3D printed in brass.
If he uses the Precision Scale frames, I think he’s going to have to drill out the cored holes in the sideframes and machine through axles anyway; he might as well fabricate lower-friction bearings or bushings to go in the drilled-out holes and make the axle ends a correct fit for the Shapeways counterweights.
Naturally if he wants to use the Shapeways rod he is going to have to very carefully drill his axle bores in the sideframes so they are spaced apart at precisely the length between eye centers – there is very little room for play in those rod eyes where they would pin to the counterweights. That also implies that he take great pains to drill exactly square to the frames, and take similar care to fit the bolster correctly to put the truck in square. All that is likely to be no fun without a proper drill-press fixture and perhaps some jigs.
As with electrically-driven model reciprocating locomotives, it is very important that the two wheelsets be in exactly the same angle of quarter, but not that they be precisely 90-degree quartered.
The horizontal engine and steamline joints and piping for this truck is Precision Scale #3297, which was available as eBay #233311546797 ($10 plus $5.05 shipping)
If it comes down to that, I have access to a pretty decent machine shop, and several machinists who have a lot of skills I don’t, as well as a number of 3d printers that are better than the four I have, and 3D modelers who are faster and more skilled than I am.
But that’s probably even further down the list than spending several hundred dollars on a functioning model and cannibalizing it.
Great info in the conversation though, I appreciate everybody’s input.
