OK, I am a little confused. Which HO narrow gauge scale will fit on N scale track. I think it is HOn30, but am not sure.
Thanks,
Tony
Hello Tony,
That’s right. N standard gauge track is 9mm wide (hence the name for “N” scale), while HOn3 is 10.5mm.
Paul
Hello Tony,
You’re right, N scale track has the same, or almost so, width as 30"-gauge track in HO scale.
There were protoytpe 30"-gauge railroads, by the way, mostly in Central and South America, as well as Germany, but two were in California.
Regards,
Paul Schmidt
Contributing Editor
Trains.com
Thanks Paul, I guess then that HOn3 would be a tad bigger at 36" and would not fit N gauge track.
Tony
Hi.If you type HOn30 into the Yahoo search engine you should get some results.There are a few HOn 30 modelers out there.One of the difficulties is finding a N scale steam loco that runs good enough.
