ho Rivarossi Blue Goose tear down
I have an old Blue goos that is not getting power from the wheels. The motor runs fine if I connect to the exposed connection at the back of the loce. I cannto seem to get the body off. I do not wish to break anythign so I am asking if anyone can give me a hint on how to get it apart. I have removed thte screws but the body seems to be stuck. Alos if you could tell me where the pickups are for the wheels tht would be a great help.Thanks
There is two screws under the back truck that need to be remove one screw in the leading truck. The bullet nose comes off if you pull on it be careful of the handrails. Also you might need to disconnect the back handrails for the cab. Once you do all the above steps if i remember right it should seperate the boiler and cab with the running gears / chassis.
The site below has the old expose diagram it should help.
http://nnrrco.raybuettner.com/rivarossi_parts.php
http://nnrrco.raybuettner.com/pdfx/Blue%20goose.pdf
