I am building a little dynamite shed for my ho mine structure. I am using Bar Mills wood shingles. I understand how to apply the shingles in rows going up each of the two sies of the roof. But when you get to the ridge line at the top, what is a realistic way to finish off the roof? Would there be metal flashing? Need help!
Google is your friend here, just search for wood shingle roof ridge, and see how the real roofs are done.
There usually is a metal cap over the ridge, and nails with neoprene or rubber washers are used to fastened the individual shingles that make the ridge.
I would think that in HO scale, all of that isn’t necessary. Just cut smaller shingles that give the look you want, and leaves the same “reveal” as the rest of the roof.
I looked at the roof on my house. I just have a row of shingles that goes over the peak in the roof. I guess you would need to cut individual shingles and put them in place one at a time.
there are many different ways depending upon era of building , one way was to run shingles up tp peak on one side then saw it to roof slope , the run shingles on other side over the top then trimmimg them . or lay up to last row on both sides trim and install preformed tin cap(some were fancy). another way was to use ridge boards (boards nailed togather at roof angle). the other posters describer other ways . for your building a ridge board would be most likely.
I should point out that I am talking about “wood” shingles in this application. And I should have specified that I am modeling in the late forties to early fifties era.
Hand split Cedar Ridge cap has been sold prefabricated in bundles for many many decades.
Even before they were sold prefab the roofers would make their own.
Just Google hand split Cedar Ridge cap and you will get more pictures than you know what to do with. It will help you understand how this process works.
Years ago the Campbell kits came with a cap strip for their shingles. I made my own by cutting off the sides (shingle cuts) and folding in the middle in my later builds.
I’m just finishing my first Plastruct Styrene shingle roof and after weathering it looks good enough to go without a cap. The Testers liquid plastic cement melted the top where the sheets join and it ended up looking like a bead cap.
This is my first attempt at Styrene shingles, it took umpteenth times to make them look real enough to put on my layout. I normally use Campbell #800 shingles but several years ago I picked up a package of Plastruct shingles so I decided to give them a go. I don’t use Styrene in my scratch builds so this was a steep learning curve for me.
Mel
Some thing you might be able to incorporate into your shed. A soft wall. Most powder magnazines had a wall that was very lightly constucted. One wall might be wood studs with tar paper on the outside. If there was an explosion, this wall would blow out and leave the building standing. This soft wall was usually faced away from other buildings.
Mel
I rarely use the Testors plastic glue in the tube for the same reason you mentioned. I use the Testors Liquid Cement #3507, its metered very fine through the long pointed nozzle and it melts the Styrene too. I’ve never had it go bad all the way to the end.
One tip I can pass on is the Testors plastic cement (3507) can get under your skin by taking way to long to come out of the nozzle. I made a holder to set the container in that keeps the nozzle pointing down while I’m using it, with the nozzle pointed down it is ready to go quickly.
Mel
Its supper runny and does flow everywhere quickly. I’ve been using it for years and never been disappointed yet, since Plasticville days back in the 60s. It fuses Styrene.
I’ve used it to make Styrene putty, dip a .02” or .03” rod in it and you can work it just like Squadron Plastic Putty only better.
I also use it like a welding rod, dip a .02” styrene rod in it and apply as you would do if you were welding.
Mel
My brother and I used to help each other out on our modeling when we were kids. I remember he was making a mill (HO) out of the cardboard from cereal boxes. I will not ramble on about the whole thing unless you’re interested later.
He asked me if I could help him out with the roof.
My dad was a cabinet maker/carpenter with a garage full of tools so I went out to use the band saw.
I cut sporadic random slits across the whole front edge of the cereal cardboard. You know, different widths like cedar shakes. A quarter inch deep. Then I took it to the paper slicer and cut it off a half inch rip. Fresh slate, back to the band saw and repeat until I had enough of these strips to layer a roof.
We painted it kind of a light Briar tan and a light grey. Did a super diluted black wash to get in the crevices. Finished with even a lighter tanish white dry brushing.
It looked great. It looked like a weathered wood roof and the best part basically free.
