HO Scale 4-4-0 possibilities
As I said before, Bachmann UK products both in N scale and OO scale are premium products and apparently of much better quality than what is offered in the US.
However, given the more positive experience with Bachmann engines by some of the members here, I sense a strong and unjustified bias against Bachmann products. In the rare case an engine of newer design fails, Bachmann´s service department is top notch and they will go through great lengths in helping you.
I would like to hear what your specific issue with a Bachmann locomotive was. While I don’t have tons of them, the Bachmann locos I do own haven’t disappointed mechanically. The cheap-o DCC decoders installed in them have been the only disappointment and were easily replaced. What happened that turned you off from Bachmann?
I have a Bowker 2-4-0 and the Inyo 4-4-0 both with old tender drive motors. I’m looking at replacing them at some point to small can motors with gear boxes. I don’t plan on totaly eliminating the tender drive though.
One way to slow down those small high RPM motors is with a gearbox to reduce output RPM and a gearbox will also multiply torque using those small motors. An example is the motors sold by Pololu at pololu.com. Similar motors are also sold on Ebay.
There are a good variety of brass HO scale 4-4-0 models available with the motor in the boiler. They mostly seem to be older models from the 60s and 70s, but they would be a good starting point for your civil war fleet.
The only more modern models seem to be of Jupiter and 119.
The prices range from $200.00 to $400.00 for a lot of the models in good condition.
-Kevin
Bachmann’s solved the gear issues at this point. The last one I know of to have any real problems was the first run of the Climax.
So far, essentially all post-2000 Bachmann models I’ve owned from standard to Spectrum have been some of my most dependable runners. This is working next to Kato, Athearn, Atlas, BLI, Proto, and other well regarded brands for both steam and diesel. The updated 4-4-0 uses a small coreless motor and high torque gearing, all contained within the firebox. A bad one gets out every now and then, but most of what I’ve heard has been good things. Just don’t pay full MSRP.[:)]
I used to get some ridicule for using Bachmann products. It mostly came from people who had a bad experience in the 80’s and 90’s. Some of those people eventually ended up with a newer model and didn’t have such a bad opinion afterward.
