Ho Scale Feet on Regular tape mesure/ ruler???
Hello all
how do i measure HO scale feet with a regular ruler/ tape measure?
I know theres a ruler made for HO but dont have one yet… also any ideas on cheapest place to find one…
Thanks all Hobojim
Thanks for all your help!! found a converter on line…
Hobo Jim
If you have a ruler with metric, 3.5mm = 1 foot. Otherwise, 1 inch on a regular ruler/tape = 7’3". Good luck converting fractions of that.[:-^] Gary
[(-D] No kidding! In decimal format, 0.138" = 1’ as a fraction it would be 69/500ths of an inch. [%-)]
Heh Heh! In N scale 1/16" = 10 scale inches, 3/4" = 10 scale feet. Not too hard to figure the fractions. (Funny that the “N” in N Scale refers to "N"ine milimeter gauge)
Sorry that this doesn’t help you too much though Mr. H. Jim
BAH! N-SCALE! [;)]
As I sit here, happily measuring 1:80 of the given metric dimensions of my prototype with:
  • A meter stick.
  • A 12" school ruler with a metric scale on one edge.
  • A (Japanese-made) 3.5M tape.
I can’t help feeling for you scrambled-dimension modelers. (Why measure English-measurement prototypes in Metric-measurement?[%-)])
The only method which will allow you to measure quickly and retain your sanity is to acquire a proper scale rule. Then use it to mark the back side of a flexible tape, so you can measure longer dimensions easily.
Agreed! Buying a scale rule was one of my better purchases. I never thought of making a custom tape measure though…not a bad idea. [tup]
Hey Hobojim,
Check out Walther’s website or catalog. They have several.
N scale 1 inch = 13.3 ft.
HO scale 1 inch = 7.2 ft.
S scale 1 inch = 5.3 ft.
O scale 1 inch = 4 ft.
Hi,
All of the previous postings are certainly “on track”. To add to them, an easy “ballpark” measurement is simply 1/8 inch equals 1 foot. Again, that’s Wrigley Field ballpark, but it will certainly expedite doing estimates (obviously, use the exact conversion for construction or the like).
Mobilman44
1/8"-1’ is more economical. You get 9 more scale feet per inch.[:o)] Actually that is 1/96th scale, common for model ships.
Hey, reklein - Not to be too picky, but HO scale is 1:87, so compared with 1:96, it’s 9 more feet per FOOT, or 9 more INCHES per inch. 1 inch is 7.3 HO feet, so 9 more feet would be quite a change of scale…
  • Gerhard
