Does anyboy know where I could find some HO scale printouts of various ground textures?
I need in particular:
- Grey gravel
- Grass
- Dirt with sparse grass growth
- Snow
- Lake or Lakebed
Please help me with this.
Printouts? Like on paper?
Ground foam isn’t that expensive, plus it looks much better. Even if you don’t have space (or money) for a permanent layout, you could build a layout on a piece of plywood that you could slide under your bed. That way you could use standard ground foam texture for grass, dirt for roads, and sifted gravel for…gravel![;)]
Alternately ground cover can be made from dyed sawdust or you can put dye or latex paint in a blender with chunks of torn up foam rubber and make your own ground foam.
This link was posted recently. Maybe there is something there for you?
A similar topic.
Are you just looking for pictures of those things so you know what they should look like when you actually model them?[%-)]
Your not planning on gluing pictures of ballast under your track, are you?? Or pictures of grass to a hillside?
I beleive the OP is looking for those to set up temporarily because of lack of room for a permanent layout.
