Can anyone give some advice as to what manufacturer they’ve used (successfully) for their HO signals? I’m trying to pick a good manufacturer for block signals and other signals as appropriate i.e. dwarf signals for yard or station use.
Tomar is an excellent company. I have some of there Semaphores and they look and work bueatifully. They also make block siganling and dwarf signals. All are powered by LEDs and you can purchace directly from them.
I like to scratch build my signals using brass tube, brass bar stock, brass ladder, bi-color leds, small washers, some small wire, balsa wood for the base, and .005 sheet styrene for the lens covers. A bit of soldering, CA glue, and walhaa a signal. They take about three hours to build. It’s the most economical way if you plan on lots of signals but the companies aboved mentioned like Oregon rail supply and tomar make nice pre-assembled signals. I also like to use DALLEE electronics train detection circuits to drive the signal lighting.The DALLEE system components are really simple to wire for train detection and work with both DC and DCC…here’s a pic of one of my scratch built signals.
